Doppellhelix 17 Posted December 24, 2022 Posted December 24, 2022 Hallo alles zusammen, ich habe mal mit den Cinema Intro und dem Trailer Plugin rumgespielt. Eigentlich ne schöne Sache. Wenn man einen Trailer abbrechen könnte. Aber ich weiß nicht, wie man das macht. Beziehe mich gerade auf Emby für Samsung TVs. Bei der Emby App, z.b. für Waipu TV habe ich es noch nicht probiert. Gruß Helix
ebr 16334 Posted December 24, 2022 Posted December 24, 2022 5 hours ago, Doppellhelix said: If you could cancel a trailer Hi. You should be able to just skip ahead to the next item with the ->| button on the OSD.
Doppellhelix 17 Posted December 25, 2022 Author Posted December 25, 2022 Good morning and Merry Christmas Yes, in the normal Android app or in the browser this is possible. Unfortunately not in the Samsung Tizen app. There is no button in the trailer. Also, the fast forward function is out of order. You can fast forward the timeline, but then it jumps back to the current position. This is probably all because Tizen is an innoficial solution, as I understood it.
Luke 42240 Posted December 26, 2022 Posted December 26, 2022 Hi, what version of the Emby Samsung app do you have?
Doppellhelix 17 Posted December 26, 2022 Author Posted December 26, 2022 I always have the latest version. 1.4.9
Luke 42240 Posted December 26, 2022 Posted December 26, 2022 Quote There is no button in the trailer. What button do you mean?
ebr 16334 Posted December 26, 2022 Posted December 26, 2022 4 minutes ago, Luke said: What button do you mean? On 12/24/2022 at 10:15 AM, ebr said: You should be able to just skip ahead to the next item with the ->| button on the OSD
Doppellhelix 17 Posted December 26, 2022 Author Posted December 26, 2022 In a normal movie I have buttons to stop, pause or rewind the movie. I don't have these in the trailer. With a Samsung TV, I can fast forward using the remote control and the directional pad on the remote. But when I release the button on the remote, the trailer jumps back to the point where I started fast forwarding. All in all, I have no chance to cancel the trailer or skip to the end. Übersetzt mit DeepL https://www.deepl.com/app/?utm_source=android&utm_medium=app&utm_campaign=share-translation
Doppellhelix 17 Posted December 26, 2022 Author Posted December 26, 2022 2 hours ago, Doppellhelix said: With a Samsung TV, I can fast forward using the remote control and the directional pad on the remote. But when I release the button on the remote, the trailer jumps back to the point where I started fast forwarding.
Luke 42240 Posted December 27, 2022 Posted December 27, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
