VicMoore 755 Posted December 23, 2022 Posted December 23, 2022 I have written a tool for editing Emby images (Primary, Logo, and Backdrop) and have run into cors problems when trying to modify or save these images. I fetch the images via the Emby API and display them on a Javascript canvas. When I extract the image from the canvas I get a "tainted image error." Uncaught DOMException: Failed to execute 'toDataURL' on 'HTMLCanvasElement': Tainted canvases may not be exported. I am using the Javascript download program below. How do I modify this code to work with Emby so that "cors" works and allows me to use the image I fetch? Vic async function download(url, callback, options) { let myHeaders = new Headers(); myHeaders.append('pragma', 'no-store'); myHeaders.append('cache-control', 'no-store'); // reload, no-store, no-cache let myRequest = new Request(url, { method: 'GET', //headers: myHeaders, mode: 'cors', //cache: 'no-store' }); let data = await (await fetch(myRequest).catch(handleErr)).json(); if(data.code && data.code==400) { console.log("=== Error 400 ",data.code); } else { //console.log("=== Fetched Obj = ",data); callback(data, options); }; function handleErr(err) { let resp = new Response( JSON.stringify({ code: 400, message: "Error" }) ); return resp; }; };
Luke 42237 Posted December 23, 2022 Posted December 23, 2022 Did you try removing the mode param, or isn't there a no-cors option on it if I recall?
VicMoore 755 Posted December 24, 2022 Author Posted December 24, 2022 tried both and neither worked. Vic
VicMoore 755 Posted December 24, 2022 Author Posted December 24, 2022 Would it be possible to add an API to set the HTTP server's CORS headers? Vic
Luke 42237 Posted December 24, 2022 Posted December 24, 2022 I don't think that's necessary because it already does. I'll have to look at what the web app is doing.
VicMoore 755 Posted December 24, 2022 Author Posted December 24, 2022 (edited) The tool is attached. Sign-on to your emby server, navigate to a movie and click on it. Select edit and the movie metadata editor will come up. now click edit image. The image editor experiences the CORS problem. Vic tool - luke.zip Edited December 24, 2022 by VicMoore
Cheesegeezer 3106 Posted December 24, 2022 Posted December 24, 2022 Unfortunately Vic its a security feature in browsers now because Javascripts are readable by every browser. Https would work. Alternatively you could use nodeJS which would also get you round the problem. i have had issues before and its a silly one that i forgot to add the http:// to the beginning of the request. That always threw the CORS error too.
VicMoore 755 Posted December 24, 2022 Author Posted December 24, 2022 Thanks Cheesegeezer for the info. If I understand right, and I frequently don't, converting the Emby server to HTTPS will solve the problem? I checked and I always add the HTTP:// to my requests. Thanks for pointing out this possible problem. Vic
Cheesegeezer 3106 Posted December 24, 2022 Posted December 24, 2022 49 minutes ago, VicMoore said: Thanks Cheesegeezer for the info. If I understand right, and I frequently don't, converting the Emby server to HTTPS will solve the problem? yep sure would because its secure. If you noticed before with swagger and the api, in order to access the api, after the CORS security was introduced, we had to change the http physical swagger address to https and then it would work. cors is only enforced when not accessing local addresses and by that i mean if you test on same server that is hosted on same dev laptop, it will be fine, but accessing another address on the network will fire up the cors issue. 49 minutes ago, VicMoore said: I checked and I always add the HTTP:// to my requests. Thanks for pointing out this possible problem. Vic Yeah it killed me for days wondering why lol then i posted here in the dev section and someone kindly pointed that out to me and all was good. merry Christmas Vic and hope you have a good ones.
VicMoore 755 Posted December 24, 2022 Author Posted December 24, 2022 (edited) Thanks Cheesegeezer I will try to convert to https. It will be a learning experience. If you have a spare moment try the app I posted above and let me know if the image editor works when you are running HTTPS. I dont have the save keys enabled so it will not save anything. Merry Christmas, Vic Edited December 24, 2022 by VicMoore
Cheesegeezer 3106 Posted December 24, 2022 Posted December 24, 2022 2 hours ago, VicMoore said: Thanks Cheesegeezer I will try to convert to https. It will be a learning experience. If you have a spare moment try the app I posted above and let me know if the image editor works when you are running HTTPS. I dont have the save keys enabled so it will not save anything. Merry Christmas, Vic I will for sure fire it up, but wont be till 27th, someone invented Xmas and we now have to cook for a Roman legion these days lol have a good one and catch you on the flip side
Luke 42237 Posted December 25, 2022 Posted December 25, 2022 If you want to mirror what our javascript does, try removing mode from your fetch requests and instead specfying: credentials: 'same-origin'
VicMoore 755 Posted December 26, 2022 Author Posted December 26, 2022 (edited) Luke, I tried your suggestion and it didn't work. Vic async function download(url, callback, options) { let myHeaders = new Headers(); myHeaders.append('pragma', 'no-store'); myHeaders.append('cache-control', 'no-store'); // reload, no-store, no-cache let myRequest = new Request(url, { method: "GET", credentials: 'same-origin' //headers: myHeaders, //mode: "cors" //cache: 'no-store' }); let data = await (await fetch(myRequest).catch(handleErr)).json(); if(data.code && data.code==400) { console.log("=== Error 400 ",data.code); } else { //console.log("=== Fetched Obj = ",data); callback(data, options); }; function handleErr(err) { let resp = new Response( JSON.stringify({ code: 400, message: "Error" }) ); return resp; }; }; Edited December 26, 2022 by VicMoore
roaku 842 Posted December 26, 2022 Posted December 26, 2022 Have you tried the recommendations here? https://stackoverflow.com/questions/25753754/canvas-todataurl-security-error-the-operation-is-insecure
VicMoore 755 Posted December 26, 2022 Author Posted December 26, 2022 Thanks Roaku for the link. I tried every proposed solution. None worked. Vic
Cheesegeezer 3106 Posted December 26, 2022 Posted December 26, 2022 7 hours ago, VicMoore said: Thanks Roaku for the link. I tried every proposed solution. None worked. Vic Hi Vic, you have an issue with your url call, it should not start with File:// this is why the cors error is being triggered. double check it. In fact log the call(GET) to the url to console so you can see exactly what is being sent.
Cheesegeezer 3106 Posted December 26, 2022 Posted December 26, 2022 @VicMoore This may have some info in that could help you also.
