chrischalfin 0 Posted December 23, 2022 Posted December 23, 2022 Hi, I am having this problem for a while now and tried to find the solution in former topics facing with file/folder permission issues in Linux. I think I tried a lot, but still without success. What am I trying to do? I want to save all metadata changes, made within emby, saved as an album.nfo file in the album-folder. I just want to make sure, that all changes I made are permanently saved and can be exported when necessary. My library setup My music is physically stored on a network drive, which is configured as a samba share. I mount this share with a dietpi-raspberry and emby is running on that raspberry. I checked file permissions, the mount has owner and group emby. So that should work? What did I do so far? I activated nfo as metadata reader and safer in the library. I change the album genre in emby and save it. My expectation is, that this change would reflect in an album.nfo file? But nothing happens. Log Output This is what I get: 2022-12-23 06:23:45.109 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.7.11.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_armhf.deb Operating system: Linux version 5.10.103-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #152 Framework: .NET 6.0.8 OS/Process: arm/arm Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/mnt/MusicLibrary/iTunes/Queen/Jazz/album.nfo' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.RandomAccess.WriteAtOffset(SafeFileHandle handle, ReadOnlySpan`1 buffer, Int64 fileOffset) at System.IO.Strategies.BufferedFileStreamStrategy.FlushWrite() at System.IO.Strategies.BufferedFileStreamStrategy.Dispose(Boolean disposing) at System.IO.Stream.Dispose() at NfoMetadata.Savers.BaseNfoSaver.SaveToFile(Stream stream, String path, LibraryOptions libraryOptions, CancellationToken cancellationToken) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveMetadata(BaseItem item, LibraryOptions libraryOptions, ItemUpdateType updateType, IMetadataSaver[] savers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void WriteAtOffset(Microsoft.Win32.SafeHandles.SafeFileHandle, System.ReadOnlySpan`1[System.Byte], Int64) InnerException: System.IO.IOException: Permission denied Source: TargetSite: My question: What could possibly still go wrong? I know everything looks like a classic linux permission problem, I just already tried many configurations with no luck. Is there another cause for this problem? Or am I missing something else? I hope you can help me Thank you!
Luke 42245 Posted December 26, 2022 Posted December 26, 2022 HI there, it looks like Emby Server is being denied write access by your file system. Have you taken a look at this?
chrischalfin 0 Posted December 28, 2022 Author Posted December 28, 2022 Thank you for your reply! I already found that article and followed the instructions. Unfortunatelly It didn´t solve my problem. My current permission status for my music library is the following: drwxr-xr-x 2 emby emby 0 Aug 8 20:50 MusicLibrary The user emby should have write permission. Maybe it´s important to know, that the folder is mounted via samba share and the following entry in fstab: //192.168.178.XX/MusicLibrarySamba /mnt/MusicLibrary cifs cred=/var/lib/dietpi/dietpi-drive_manager/mnt-MusicLibrary.cred,iocharset=utf8,uid=emby,gid=emby,file_mode=0755,dir_mode=0755,vers=3.1.1,nofail The corresponding configuration in smb.conf is the following: [MusicLibrarySamba] path=/media/myCloudDrive/music writeable=yes valid users = SambaUser force user = sambauser force group = sambauser The music folders permission settings: drwxr-xr-x 1 sambauser sambauser 144 8. Aug 21:50 music One possibility is, that maybe the different user names emby and sambauser might cause the problem?
Solution Happy2Play 9812 Posted December 28, 2022 Solution Posted December 28, 2022 Possible noblr issue? 1
chrischalfin 0 Posted December 29, 2022 Author Posted December 29, 2022 Amazing! Thank you @Happy2Play, that solved the problem. This kept me up for a very long time now, next time I will post my issues earlier
Q-Droid 1011 Posted December 29, 2022 Posted December 29, 2022 On 12/28/2022 at 4:15 PM, Happy2Play said: Possible noblr issue? I thought that would have been fixed in .Net 6. Go figure.
