mturcotteinfo 0 Posted December 23, 2022 Posted December 23, 2022 Hi, My tv show put season 1, season 2 and etc. But all my folder is good renomed. So how fix this problem? Thanks
Luke 42186 Posted December 25, 2022 Posted December 25, 2022 Hi there, how did you configure the TV library in Emby library setup?
Luke 42186 Posted December 26, 2022 Posted December 26, 2022 1 hour ago, mturcotteinfo said: I potted tvDB for metadata Can you please show us all of the options for the library? Thanks.
mturcotteinfo 0 Posted December 26, 2022 Author Posted December 26, 2022 Now you can see picture… juste the name is not good but description is good lettree A until R is good and after not good
Luke 42186 Posted December 26, 2022 Posted December 26, 2022 Can we see the library folders in emby library setup? Thanks.
mturcotteinfo 0 Posted December 31, 2022 Author Posted December 31, 2022 I create other emby server and I have same problem
Luke 42186 Posted January 2, 2023 Posted January 2, 2023 Can you please show the file contents of the midnight mass folder? Thanks.
mturcotteinfo 0 Posted January 11, 2023 Author Posted January 11, 2023 (edited) Edited January 12, 2023 by Happy2Play removed WAN
Happy2Play 9800 Posted January 20, 2023 Posted January 20, 2023 What created your nfo files as it appears they are disabled per the images you provided. Nothing overall stands out here but the nfo files.
