Guest Posted December 22, 2022 Posted December 22, 2022 Can anyone help me remove unwanted users from my emby account? I have changed my password, but doing so does not log off a user that is currently on. Any help is appreciated! Sean
Abobader 3485 Posted December 22, 2022 Posted December 22, 2022 Hello Callahan.sean.d, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
rbjtech 5335 Posted December 22, 2022 Posted December 22, 2022 (edited) 52 minutes ago, Callahan.sean.d said: Can anyone help me remove unwanted users from my emby account? I have changed my password, but doing so does not log off a user that is currently on. Any help is appreciated! Sean Disable the user, then re-enable it - this will force re-authentication using your new password. If this is your only user - then create another Admin user first, then logon as that Admin, THEN disable the other account. Remove the temp Admin account once you are happy. Edited December 22, 2022 by rbjtech 4
Guest Posted December 24, 2022 Posted December 24, 2022 Can you explain how to disable the user, which I assume you mean my account? The only options I see are 1) delete account, and 2) view current devices (which is not even showing me the devices that I know are on for a fact). Thanks for any help!
Abobader 3485 Posted December 24, 2022 Posted December 24, 2022 Good day, I removed the login's devices from your account, regarding the solution giving above, from your emby server dash/setting, click on users, then do as suggest. My best 1
CeeBee 1 Posted November 30, 2023 Posted November 30, 2023 (edited) NOT at all ... I even deleted the user account .. readded 10 minutes later, changed password .. restarted the server just for good measure .... and still no password prompt .. can access the server again just fine ... serious flaw this is yes ? Edited November 30, 2023 by CeeBee
rbjtech 5335 Posted November 30, 2023 Posted November 30, 2023 1 hour ago, CeeBee said: NOT at all ... I even deleted the user account .. readded 10 minutes later, changed password .. restarted the server just for good measure .... and still no password prompt .. can access the server again just fine ... serious flaw this is yes ? Which emby client ? If I change password via the web client - it immediately throws out that user. Same with a user disable - the session is terminated and requires the user to log back in again.
