NormSwarm 13 Posted December 21, 2022 Posted December 21, 2022 (edited) Hello, So, I'm using linuxserver/emby:beta for my docker image, I've passed the devices /dev/dri/card0 and /dev/dri/renderD128 to the container. Emby doesn't detect all the available profile for decoding and encoding (Also, I have an active Emby Premiere subscription). I've installed into the image `vainfo` into the container to check that everything is good and I see all the profile (like HEVC, H264): root@bd304a409b20:/# vainfo error: XDG_RUNTIME_DIR not set in the environment. error: can't connect to X server! libva info: VA-API version 1.14.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.14 (libva 2.12.0) vainfo: Driver version: Mesa Gallium driver 22.0.5 for AMD Radeon Vega 3 Graphics (raven, LLVM 13.0.1, DRM 3.47, 5.19.17-Unraid) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc As you can see, there are more profile than just MPEG-2 and VP9, but those aren't found by emby. To test further, I've installed Jellyfin image. I've configured it to use hardware decoding using vaapi and selected the HEVC decoding (normal and 10 bit). I tested to stream to the browser a hevc 10bit file, it used hardware decoding without any issue. I check the GPU usage with radeontop. Here is a transcode log from jellyfin proving that ffmpeg had no issue using the device. transcode-log-jellyfin.log Emby hardware detection log: hardware_detection-63807243716.txt What can I do to force Emby to recognize the VAAPI profiles ? Edited December 21, 2022 by NormSwarm Adding more logs
NormSwarm 13 Posted December 22, 2022 Author Posted December 22, 2022 Also wanted to add, I have the same result with the official docker image emby/embyserver:beta which was the image I was using before. I've switched to LinuxServer because it was easier for me to install vainfo into it.
NormSwarm 13 Posted December 22, 2022 Author Posted December 22, 2022 (edited) Would you have any suggestion @softworkz ? Edited December 22, 2022 by NormSwarm
Solution NormSwarm 13 Posted December 23, 2022 Author Solution Posted December 23, 2022 So I've been digging more, making ffdetect just ouput the proper JSON I need to force the encoder/decoder. Now when I actually trigger a transcoding I see this: 22:10:17.868 [AVHWDeviceContext @ 0x70f5c0] libva: dlopen of /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so failed: /app/emby/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so) I have the feeling this is the source of all the problems. This is the version available of GLIBCXX in the libstdc++ provided by emby: root@bd304a409b20:/# strings /app/emby/libstdc++.so.6 | grep GLIBCXX GLIBCXX_3.4 GLIBCXX_3.4.1 GLIBCXX_3.4.2 GLIBCXX_3.4.3 GLIBCXX_3.4.4 GLIBCXX_3.4.5 GLIBCXX_3.4.6 GLIBCXX_3.4.7 GLIBCXX_3.4.8 GLIBCXX_3.4.9 GLIBCXX_3.4.10 GLIBCXX_3.4.11 GLIBCXX_3.4.12 GLIBCXX_3.4.13 GLIBCXX_3.4.14 GLIBCXX_3.4.15 GLIBCXX_3.4.16 GLIBCXX_3.4.17 GLIBCXX_3.4.18 GLIBCXX_3.4.19 GLIBCXX_3.4.20 GLIBCXX_3.4.21 GLIBCXX_3.4.22 GLIBCXX_3.4.23 GLIBCXX_3.4.24 GLIBCXX_3.4.25 GLIBCXX_3.4.26 GLIBCXX_3.4.27 GLIBCXX_3.4.28 GLIBCXX_DEBUG_MESSAGE_LENGTH In comparison, this is the list of version available provided by Ubuntu: root@bd304a409b20:/# strings /usr/lib/x86_64-linux-gnu/libstdc++.so.6 | grep GLIBCXX GLIBCXX_3.4 GLIBCXX_3.4.1 GLIBCXX_3.4.2 GLIBCXX_3.4.3 GLIBCXX_3.4.4 GLIBCXX_3.4.5 GLIBCXX_3.4.6 GLIBCXX_3.4.7 GLIBCXX_3.4.8 GLIBCXX_3.4.9 GLIBCXX_3.4.10 GLIBCXX_3.4.11 GLIBCXX_3.4.12 GLIBCXX_3.4.13 GLIBCXX_3.4.14 GLIBCXX_3.4.15 GLIBCXX_3.4.16 GLIBCXX_3.4.17 GLIBCXX_3.4.18 GLIBCXX_3.4.19 GLIBCXX_3.4.20 GLIBCXX_3.4.21 GLIBCXX_3.4.22 GLIBCXX_3.4.23 GLIBCXX_3.4.24 GLIBCXX_3.4.25 GLIBCXX_3.4.26 GLIBCXX_3.4.27 GLIBCXX_3.4.28 GLIBCXX_3.4.29 GLIBCXX_3.4.30 GLIBCXX_DEBUG_MESSAGE_LENGTH If I copy the lib from the Ubuntu GLIB, everything works, ffdetect and the transcoding. Basically, the GLIB package with Emby is too old to work properly with modern version of the radeon driver. cp /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /app/emby/libstdc++.so.6 @Luke & @softworkz Please update the glib you pack inside Emby.
NormSwarm 13 Posted December 24, 2022 Author Posted December 24, 2022 So, in case anybody is interested, the fix I found only works for the linuxserver image. For the official emby image, I surmise it's related to the old version of GLIB used compared to the version of the AMD Driver installed into it (Mesa Gallium driver 22.2.3 for AMD Radeon Vega 3 Graphics (raven, LLVM 14.0.6, DRM 3.47, 5.19.17-Unraid)). I still suggest updating the libstdc++ used in the image and in the package to provide GLIBCXX 3.4.29. This is surely the source of all the other post about HW acceleration disappearing. I think the graphic drivers got updated but no the GLIB. Unfortunately, since even the Dockerfile used to create the image is closed source, I can't help more on this. Hopefully that will help @Luke and @softworkz into fixing the problem.
Luke 42245 Posted January 9, 2023 Posted January 9, 2023 On 12/23/2022 at 10:54 PM, NormSwarm said: So, in case anybody is interested, the fix I found only works for the linuxserver image. For the official emby image, I surmise it's related to the old version of GLIB used compared to the version of the AMD Driver installed into it (Mesa Gallium driver 22.2.3 for AMD Radeon Vega 3 Graphics (raven, LLVM 14.0.6, DRM 3.47, 5.19.17-Unraid)). I still suggest updating the libstdc++ used in the image and in the package to provide GLIBCXX 3.4.29. This is surely the source of all the other post about HW acceleration disappearing. I think the graphic drivers got updated but no the GLIB. Unfortunately, since even the Dockerfile used to create the image is closed source, I can't help more on this. Hopefully that will help @Luke and @softworkz into fixing the problem. @NormSwarm we will review this. Thanks !
NormSwarm 13 Posted January 9, 2023 Author Posted January 9, 2023 @Lukeif you need me to test any beta/nightly version, I'll be happy to do it 1
alucryd 318 Posted January 22, 2023 Posted January 22, 2023 @NormSwarmThe stdc++ issue only applies when you're running the linuxserver container and are trying to use anything outside of what we provide. On our image everything is compiled using the same version and should work out of the box, it doesn't matter whether it's an older version. I've updated our whole video stack, including the mesa drivers, and I pushed an image for the purpose of debugging, it includes a copy of vainfo, the tag is 4.8.0.21-debug. Could you give it a try? 1
NormSwarm 13 Posted January 22, 2023 Author Posted January 22, 2023 (edited) @alucryd Still encountering the same issue. I went reading about Mesa driver, and they removed support for hardware acceleration (avc, hevc, VC1) : https://forum.manjaro.org/t/upstream-mesa-removal-of-avc-hevc-vc-1-hardware-acceleration-amd-gpus/128385 So basically, Emby shouldn't use the upstream version of mesa, but a patched version that re-enable the hardware acceleration (it seems Ubuntu Jammy and Arch have gone that route). Edit: if you're compiling Mesa for the package, it simply need to have the encoder/decoder enabled through configuration flags: https://forum.endeavouros.com/t/endeavouros-mesa-codec-support/34607 or more direct: https://github.com/archlinux/svntogit-packages/blob/packages/mesa/repos/extra-x86_64/PKGBUILD#L86 Trying display: drm libva info: VA-API version 1.17.0 libva info: Trying to open /lib/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_17 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.17 (libva 2.17.1) vainfo: Driver version: Mesa Gallium driver 22.3.3 for AMD Radeon Vega 3 Graphics (raven, LLVM 15.0.7, DRM 3.47, 5.19.17-Unraid) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc Edited January 22, 2023 by NormSwarm
alucryd 318 Posted January 22, 2023 Posted January 22, 2023 @NormSwarmEasy enough, will have a new beta for you tomorrow.
NormSwarm 13 Posted January 23, 2023 Author Posted January 23, 2023 @alucryd We have a fix The encoder/decoder properly show up / # vainfo Trying display: drm libva info: VA-API version 1.17.0 libva info: Trying to open /lib/dri/radeonsi_drv_video.so libva info: Found init function __vaDriverInit_1_17 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.17 (libva 2.17.1) vainfo: Driver version: Mesa Gallium driver 22.3.3 for AMD Radeon Vega 3 Graphics (raven, LLVM 15.0.7, DRM 3.47, 5.19.17-Unraid) vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileVC1Simple : VAEntrypointVLD VAProfileVC1Main : VAEntrypointVLD VAProfileVC1Advanced : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSlice VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSlice VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSlice VAProfileHEVCMain10 : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointVLD VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileNone : VAEntrypointVideoProc 1
ouch 0 Posted March 3, 2023 Posted March 3, 2023 On 12/22/2022 at 10:25 PM, NormSwarm said: So I've been digging more, making ffdetect just ouput the proper JSON I need to force the encoder/decoder. Now when I actually trigger a transcoding I see this: 22:10:17.868 [AVHWDeviceContext @ 0x70f5c0] libva: dlopen of /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so failed: /app/emby/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so) I have the feeling this is the source of all the problems. This is the version available of GLIBCXX in the libstdc++ provided by emby: root@bd304a409b20:/# strings /app/emby/libstdc++.so.6 | grep GLIBCXX GLIBCXX_3.4 GLIBCXX_3.4.1 GLIBCXX_3.4.2 GLIBCXX_3.4.3 GLIBCXX_3.4.4 GLIBCXX_3.4.5 GLIBCXX_3.4.6 GLIBCXX_3.4.7 GLIBCXX_3.4.8 GLIBCXX_3.4.9 GLIBCXX_3.4.10 GLIBCXX_3.4.11 GLIBCXX_3.4.12 GLIBCXX_3.4.13 GLIBCXX_3.4.14 GLIBCXX_3.4.15 GLIBCXX_3.4.16 GLIBCXX_3.4.17 GLIBCXX_3.4.18 GLIBCXX_3.4.19 GLIBCXX_3.4.20 GLIBCXX_3.4.21 GLIBCXX_3.4.22 GLIBCXX_3.4.23 GLIBCXX_3.4.24 GLIBCXX_3.4.25 GLIBCXX_3.4.26 GLIBCXX_3.4.27 GLIBCXX_3.4.28 GLIBCXX_DEBUG_MESSAGE_LENGTH In comparison, this is the list of version available provided by Ubuntu: root@bd304a409b20:/# strings /usr/lib/x86_64-linux-gnu/libstdc++.so.6 | grep GLIBCXX GLIBCXX_3.4 GLIBCXX_3.4.1 GLIBCXX_3.4.2 GLIBCXX_3.4.3 GLIBCXX_3.4.4 GLIBCXX_3.4.5 GLIBCXX_3.4.6 GLIBCXX_3.4.7 GLIBCXX_3.4.8 GLIBCXX_3.4.9 GLIBCXX_3.4.10 GLIBCXX_3.4.11 GLIBCXX_3.4.12 GLIBCXX_3.4.13 GLIBCXX_3.4.14 GLIBCXX_3.4.15 GLIBCXX_3.4.16 GLIBCXX_3.4.17 GLIBCXX_3.4.18 GLIBCXX_3.4.19 GLIBCXX_3.4.20 GLIBCXX_3.4.21 GLIBCXX_3.4.22 GLIBCXX_3.4.23 GLIBCXX_3.4.24 GLIBCXX_3.4.25 GLIBCXX_3.4.26 GLIBCXX_3.4.27 GLIBCXX_3.4.28 GLIBCXX_3.4.29 GLIBCXX_3.4.30 GLIBCXX_DEBUG_MESSAGE_LENGTH If I copy the lib from the Ubuntu GLIB, everything works, ffdetect and the transcoding. Basically, the GLIB package with Emby is too old to work properly with modern version of the radeon driver. cp /usr/lib/x86_64-linux-gnu/libstdc++.so.6 /app/emby/libstdc++.so.6 @Luke & @softworkz Please update the glib you pack inside Emby. Thank you for the information. I am curious about the performance of hardware accelerated transcoding with AMD 300U, do you have any data about that? Thanks agian @NormSwarm
