nuentes 41 Posted December 21, 2022 Posted December 21, 2022 I've brought this up with you before. I have path substitution enabled in my advanced preferences, so all of my artwork gets cached to an NFS server. I would like to use the "cache artwork" feature. When trying to use this feature in the past, I would always get an error that I was low on disc space. The NFS server had plenty of space, but my TV itself was low on storage, so I was unable to cache artwork. You finally added a feature where I could disable the disk space check (I'm currently on 7.13.1). I unchecked the box and started caching some artwork, and after a few minutes, I got swarmed with errors that my TV had run out of storage. So the artwork was somehow caching to the local storage, rather than to the NFS storage. The relevent section of my advanced settings file is below: <pathsubstitution> <substitute> <from>special://profile/Thumbnails/</from> <to>nfs://192.168.1.209/export/kodi/Thumbnails</to> </substitute> </pathsubstitution>
quickmic 1709 Posted December 21, 2022 Posted December 21, 2022 (edited) 58 minutes ago, nuentes said: I've brought this up with you before. I have path substitution enabled in my advanced preferences, so all of my artwork gets cached to an NFS server. I would like to use the "cache artwork" feature. When trying to use this feature in the past, I would always get an error that I was low on disc space. The NFS server had plenty of space, but my TV itself was low on storage, so I was unable to cache artwork. You finally added a feature where I could disable the disk space check (I'm currently on 7.13.1). I unchecked the box and started caching some artwork, and after a few minutes, I got swarmed with errors that my TV had run out of storage. So the artwork was somehow caching to the local storage, rather than to the NFS storage. The relevent section of my advanced settings file is below: <pathsubstitution> <substitute> <from>special://profile/Thumbnails/</from> <to>nfs://192.168.1.209/export/kodi/Thumbnails</to> </substitute> </pathsubstitution> This is an internal kodi setting and not respected by the plugin. However, why you are not just linking the folder? This would solve all you problems and is also what I'm doing on my Vero4K device. Edited December 21, 2022 by quickmic
nuentes 41 Posted December 21, 2022 Author Posted December 21, 2022 54 minutes ago, quickmic said: This is an internal kodi setting and not respected by the plugin. However, why you are not just linking the folder? This would solve all you problems and is also what I'm doing on my Vero4K device. What do you mean "linking the folder"? I'm definitely open to doing this another way. Is there no way to have the plugin respect the path substitution?
quickmic 1709 Posted December 21, 2022 Posted December 21, 2022 (edited) 8 minutes ago, nuentes said: What do you mean "linking the folder"? I'm definitely open to doing this another way. Is there no way to have the plugin respect the path substitution? Path substitutions is a very bad workaround for something which actually should be handled on os bases. ...just my two cents Use softlinks or mounts -> e.g. use ln -s or mount nfs into Kodi's thumbnail folder root@kodi-bedroom:~# ls /home/osmc/.kodi/userdata/ -All total 100 drwxrwxrwx 3 root root 4096 Dec 21 17:55 Database -rw-r--r-- 1 osmc osmc 380 Dec 21 17:19 RssFeeds.xml drwxrwxrwx 5 root root 4096 May 21 2022 Savestates lrwxrwxrwx 1 root root 23 May 21 2022 Thumbnails -> /mnt/sdcard/Thumbnails/ drwxrwxrwx 31 root root 4096 Dec 15 19:03 addon_data -rwxrwxrwx 1 root root 451 Aug 8 18:33 advancedsettings.xml -rwxrwxrwx 1 root root 86 May 21 2022 disp_cap -rwxrwxrwx 1 root root 51541 Dec 10 07:57 guisettings.xml drwxrwxrwx 2 root root 4096 May 21 2022 keymaps drwxrwxrwx 4 root root 4096 Nov 7 13:43 library drwxrwxrwx 2 root root 4096 May 21 2022 peripheral_data drwxrwxrwx 5 osmc osmc 4096 Sep 18 09:44 playlists -rwxrwxrwx 1 root root 960 Dec 21 17:36 profiles.xml -rwxrwxrwx 1 root root 271 May 21 2022 sources.xml Edited December 21, 2022 by quickmic
nuentes 41 Posted December 21, 2022 Author Posted December 21, 2022 8 minutes ago, quickmic said: Path substitutions is a very bad workaround for something which actually should be handled on os bases. ...just my two cents Use softlinks or mounts -> e.g. use ln -s or mount nfs into Kodi's thumbnail folder root@kodi-bedroom:~# ls /home/osmc/.kodi/userdata/ -All total 100 drwxrwxrwx 3 root root 4096 Dec 21 17:55 Database -rw-r--r-- 1 osmc osmc 380 Dec 21 17:19 RssFeeds.xml drwxrwxrwx 5 root root 4096 May 21 2022 Savestates lrwxrwxrwx 1 root root 23 May 21 2022 Thumbnails -> /mnt/sdcard/Thumbnails/ drwxrwxrwx 31 root root 4096 Dec 15 19:03 addon_data -rwxrwxrwx 1 root root 451 Aug 8 18:33 advancedsettings.xml -rwxrwxrwx 1 root root 86 May 21 2022 disp_cap -rwxrwxrwx 1 root root 51541 Dec 10 07:57 guisettings.xml drwxrwxrwx 2 root root 4096 May 21 2022 keymaps drwxrwxrwx 4 root root 4096 Nov 7 13:43 library drwxrwxrwx 2 root root 4096 May 21 2022 peripheral_data drwxrwxrwx 5 osmc osmc 4096 Sep 18 09:44 playlists -rwxrwxrwx 1 root root 960 Dec 21 17:36 profiles.xml -rwxrwxrwx 1 root root 271 May 21 2022 sources.xml I'll look into this solution. Thanks 1
