cmserrano89 0 Posted December 21, 2022 Posted December 21, 2022 Buenos diías, tengo el siguiente problema con la Biblioteca "Novelas", luego de agregarla no me carga la imagen y ya he probado borrar la biblioteca y agregarla nuevamente, con diferentes tipos de contenido.
Happy2Play 9811 Posted December 21, 2022 Posted December 21, 2022 Have selected edit image and delete the current image and done a library scan?
cmserrano89 0 Posted December 21, 2022 Author Posted December 21, 2022 1 hour ago, Happy2Play said: Have selected edit image and delete the current image and done a library scan? Yes, I did it a few times.
Happy2Play 9811 Posted December 21, 2022 Posted December 21, 2022 1 hour ago, cmserrano89 said: Yes, I did it a few times. Can you post a server log for that.
cmserrano89 0 Posted December 21, 2022 Author Posted December 21, 2022 21 minutes ago, Happy2Play said: Can you post a server log for that. Here you are !! embyserver.txt
Happy2Play 9811 Posted December 21, 2022 Posted December 21, 2022 Not sure why but you need to figure out your Emby Cache folder permissions issue. (C:\programdata\cache) example issue for all cached provider metadata System.UnauthorizedAccessException: Access to the path 'C:\programdata\cache\tvdb-movies\73676\movie.json' is denied.
