VirulentPip 100 Posted December 20, 2022 Posted December 20, 2022 Using both FireTV and Android apps. HDR Format: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-Ray Compatible / SMPTE ST 2086, HDR10 compatible TV triggered HDR. However, HDR format: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible TV triggered Dolby Vision. TV is LG C1 so supports Dolby Vision, HDR 10 and HLG. No HDR10+ support as you can see both have the same DV specifications, only difference is the extra compatible track. Is there any reason by DV isn't being triggered for example 1?
VirulentPip 100 Posted December 20, 2022 Author Posted December 20, 2022 (edited) So the two I tried are 13 Hours and then Alita Battle Angel. I've now just tried Aquaman (Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible) and DV is triggered. So I guess it's an issue with 13 Hours I assume this was the profile you were wanting me to test? I have no idea what the dvhe 07.06 means lol @rbjtech Edited December 20, 2022 by VirulentPip
