strager 18 Posted December 20, 2022 Posted December 20, 2022 OK - so I have Emby running on a TerraMaster using TOS3. I've been trying to connect it to a second NAS (a WDMyCloud Ex400) that has a different library on it. I can't mount it in Emby because the My Cloud requires a username/password and apparently Emby doesn't support connecting to a Samba share with one. I tried mounting it using Remote Share on the Terramaster as NFS, but it tells me it doesn't have permission to read the share. I finally mounted it as a samba share, but now it appears emby has Read permissions but not write permissions to the drive. The "admin" account on the terramaster can access it just fine. I tried SSHing in and Chmoding the file (777 with a big 'ol -R to make it apply to all the subfolders) but no luck - the 'emby' account still can't write to it. No matter what I try to do, I can't write. Is there a way I can change Emby to use the "admin" account on the terramaster instead of it's own emby account?
strager 18 Posted December 20, 2022 Author Posted December 20, 2022 Here's an example out of the logs: Quote 2022-12-20 09:48:31.558 Info HttpClient: GET https://assets.fanart.tv/fanart/movies/11974/movieposter/the-burbs-521caeeea4d73.jpg 2022-12-20 09:48:31.868 Info Server: http/1.1 POST http://192.168.1.11:8096/emby/Items/77836/RemoteImages/Download?Type=Primary&ImageUrl=https://image.tmdb.org/t/p/original/1oyRR8D5WiVHwunIkOMjl30Jdg5.jpg&ProviderName=TheMovieDb&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=77b66002-70cb-4d9f-bad7-fca163d4cd54&X-Emby-Client-Version=4.7.10.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36 2022-12-20 09:48:33.136 Info HttpClient: GET https://image.tmdb.org/t/p/original/1oyRR8D5WiVHwunIkOMjl30Jdg5.jpg 2022-12-20 09:48:33.329 Info ProviderManager: Deleting previous image /mnt/public/wdmycloudex4100/Movies/Burbs, The (1989)/poster.jpg 2022-12-20 09:48:33.455 Error Server: Error processing request *** Error Report *** Version: 4.7.10.0 Command line: /mnt/md0/application/emby/system/EmbyServer.dll -programdata /home/emby -ffdetect /usr/local/emby/bin/ffdetect -ffmpeg /usr/local/emby/bin/ffmpeg -ffprobe /usr/local/emby/bin/ffprobe -defaultdirectory /mnt/public -updatepackage emby_TOS_APP_{version}_aarch64.tpk Operating system: Linux version 4.4.18-g8bcbd8a-dirty (root@developer) (gcc version 4.9.4 (OpenWrt/Linaro GCC 4.9-2015.06 r48422) ) #1329 SMP Thu Sep 17 16:54:38 CST 20 Framework: .NET 6.0.8 OS/Process: arm64/arm64 Runtime: mnt/md0/application/emby/system/System.Private.CoreLib.dll Processor count: 4 Data path: /home/emby Application path: /mnt/md0/application/emby/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/mnt/public/wdmycloudex4100/Movies/Burbs, The (1989)/poster.jpg' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.FileSystem.DeleteFile(String fullPath) at System.IO.File.Delete(String path) at Emby.Server.Implementations.IO.ManagedFileSystem.DeleteFileInternal(String path, Boolean sendToRecycleBin) at Emby.Server.Implementations.IO.ManagedFileSystem.DeleteFile(String path, Boolean sendToRecycleBin) at Emby.Server.Implementations.IO.ManagedFileSystem.DeleteFile(String path) at Emby.Providers.Manager.ImageSaver.SaveImage(BaseItem item, LibraryOptions libraryOptions, IImageSource source, ReadOnlyMemory`1 mimeType, ImageType type, Nullable`1 imageIndex, Nullable`1 saveLocallyWithMedia, Boolean isFallbackImage, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveImageFromRemoteUrl(BaseItem item, LibraryOptions libraryOptions, String url, ImageType type, Nullable`1 imageIndex, Boolean isFallbackImage, CancellationToken cancellationToken) at Emby.Api.Images.RemoteImageService.DownloadRemoteImage(BaseItem item, BaseDownloadRemoteImage request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void DeleteFile(System.String) InnerException: System.IO.IOException: Permission denied Source: TargetSite:
squarepeg 6 Posted December 20, 2022 Posted December 20, 2022 Is there an option to mount the shared folder mapped to a specific user? This screenshot is from TOS5 and in the NFS section but maybe there is a similar option for you Also you could try doing a chown -R 999:999 on the folder (no owner) so anyone can access. Give these a try and let me know if you have any luck
strager 18 Posted December 22, 2022 Author Posted December 22, 2022 CORRECTION TO MY OP: I apparently am on TOS 4.2 not TOS 3. Not sure where I saw 3 before. Thanks for your answer @squarepeg - There was no option to mount as a specific user that I could find. I also don't have that "squash" setting or "asynchronous" anywhere. These are the only options I have for NFS: I tried to chown and it did not make a difference either
strager 18 Posted April 5, 2023 Author Posted April 5, 2023 Actually @LukeI never did... I got it to somewhat work but its still throwing the permission errors. Here's a recent one: Quote 2023-04-05 18:45:06.953 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.8.0.21 Command line: /mnt/md0/application/emby/system/EmbyServer.dll -programdata /home/emby -ffdetect /usr/local/emby/bin/ffdetect -ffmpeg /usr/local/emby/bin/ffmpeg -ffprobe /usr/local/emby/bin/ffprobe -defaultdirectory /mnt/public -updatepackage emby_TOS_APP_{version}_aarch64.tpk Operating system: Linux version 4.4.18-g8bcbd8a-dirty (root@developer) (gcc version 4.9.4 (OpenWrt/Linaro GCC 4.9-2015.06 r48422) ) #1329 SMP Thu Sep 17 16:54:38 CST 20 Framework: .NET 6.0.8 OS/Process: arm64/arm64 Runtime: mnt/md0/application/emby/system/System.Private.CoreLib.dll Processor count: 4 Data path: /home/emby Application path: /mnt/md0/application/emby/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/mnt/public/wdmycloudex4100/Movies/Batman Vs Robin (2015)/Batman Vs Robin (2015).nfo' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at Interop.CheckIo(Error error, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at NfoMetadata.Savers.BaseNfoSaver.SaveToFile(Stream stream, String path, LibraryOptions libraryOptions, CancellationToken cancellationToken) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveMetadata(BaseItem item, LibraryOptions libraryOptions, ItemUpdateType updateType, IMetadataSaver[] savers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void CheckIo(Error, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) InnerException: System.IO.IOException: Permission denied Source: TargetSite:
Luke 42237 Posted April 13, 2023 Posted April 13, 2023 @stragerit appears you enabled saving metadata to nfo files but the server is being denied write access to your media folders. I would suggest resolving those permissions or just turning off nfo file saving. Please let us know if this helps. Thanks.
strager 18 Posted May 13, 2023 Author Posted May 13, 2023 That's the bulk of the issue. I can't seem to give Emby permission to write. I've tried everything I can think of, but there seems to be no way to give it credentials and even when I changed the permissions on the folders to 777 it still gives the error.
Luke 42237 Posted May 22, 2023 Posted May 22, 2023 @stragerdid you figure out how to set the permissions?
