Mathisssimo 0 Posted December 19, 2022 Posted December 19, 2022 Hey, I wanna have a NAS for my Emby. I have google tv where I can run Emby. But I don't want to spent to much money on it. Now its running on a desktop that takes a lot of energy.
Luke 42237 Posted December 20, 2022 Posted December 20, 2022 Hi, how about a Synology? They're very popular around here.
Mathisssimo 0 Posted December 20, 2022 Author Posted December 20, 2022 Yes but which one is good for an emby server and storage
Luke 42237 Posted December 21, 2022 Posted December 21, 2022 If you need two drives, how about the DS-220+? If you need four drives, there's the DS-920+. Both great options.
Mathisssimo 0 Posted December 22, 2022 Author Posted December 22, 2022 Allright. that is option 1 But what if, i want to instal it on a H96 4K 4gb RAM android box, with a SSD storage. is it possible? Or do I need to instal storage on the router who has a 3.0 USB port. Also is it possible to put Home Assistant server on that same box
Solution Luke 42237 Posted January 9, 2023 Solution Posted January 9, 2023 On 12/22/2022 at 8:21 AM, Mathisssimo said: Allright. that is option 1 But what if, i want to instal it on a H96 4K 4gb RAM android box, with a SSD storage. is it possible? Or do I need to instal storage on the router who has a 3.0 USB port. Also is it possible to put Home Assistant server on that same box HI, yes we do have Emby Server for Android, but not for routers.
