lllmajor1997 1 Posted December 19, 2022 Posted December 19, 2022 (edited) Has anyone used Twingate to securely connect to Emby? I was reading the Emby remote setup guide and it recommended port forwarding. I'm using T Mobile home internet, so I can't use port forwarding, and I found Twingate which seems to solve this problem. I found this guide for Plex, so I'm assuming it will work if I just use port 8096: https://www.twingate.com/blog/windows-plex-remote-access-without-port-forwarding/ Edited December 19, 2022 by lllmajor1997
happycamper1982 1 Posted December 19, 2022 Posted December 19, 2022 I have! I actually heard about twingate from a coworker who highly recommended the service. I haven't tried configuring twingate with t mobile home internet, but I'm not a fan of having open ports which made port forwarding a no go for me. Was simple to set up on my Synology using the Docker deployment option. Let me know if you need any help but felt pretty intuitive if you are familiar with Docker. They also mention a couple of other deployment options in their docs: https://www.twingate.com/docs/connector-deployment/ 1
lllmajor1997 1 Posted December 20, 2022 Author Posted December 20, 2022 (edited) 15 hours ago, happycamper1982 said: I have! I actually heard about twingate from a coworker who highly recommended the service. I haven't tried configuring twingate with t mobile home internet, but I'm not a fan of having open ports which made port forwarding a no go for me. Was simple to set up on my Synology using the Docker deployment option. Let me know if you need any help but felt pretty intuitive if you are familiar with Docker. They also mention a couple of other deployment options in their docs: https://www.twingate.com/docs/connector-deployment/ Thanks! I just set it up with docker in less than 30 minutes. Edited December 20, 2022 by lllmajor1997 1
simonguillot@yahoo.ca 1 Posted February 3, 2024 Posted February 3, 2024 Hi guys I am at loss What is the best option? I heard cloudflare is no go. Now twingate? I desperately need help to acces my wmby server and file server TIA
Luke 42241 Posted February 3, 2024 Posted February 3, 2024 1 hour ago, simonguillot@yahoo.ca said: Hi guys I am at loss What is the best option? I heard cloudflare is no go. Now twingate? I desperately need help to acces my wmby server and file server TIA Hi, can't you just configure remote access without cloudfare or twingate? Do you have to use one of those? Remote Setup
simonguillot@yahoo.ca 1 Posted February 3, 2024 Posted February 3, 2024 I use to have port forwarding to get in. Now it's not available and I don't know what to do
simonguillot@yahoo.ca 1 Posted February 3, 2024 Posted February 3, 2024 Oh Look at that It works even without port forwarding Thanks for the hints 1
