YanTomJoe 1 Posted December 19, 2022 Posted December 19, 2022 Impossible to connect my serveur EMBY (1.6.8) on AppleTV 4K (16.2). Cogwheel pictogram rotates endlessly when I enter my server adress or when I use EMBY connect.(emby.media/pin) However it’s work on iPhone with the same setting… Someone has the same problem ?
Luke 42240 Posted December 19, 2022 Posted December 19, 2022 Hi there, are you sure you entered the correct address? How did you enter it into the app?
YanTomJoe 1 Posted December 20, 2022 Author Posted December 20, 2022 Hello, the problem bas been fixed. It was because of the version of DSM. After migration DSM 6 to DSM 7, ans update emby server, it works. Thanks ! 1
