codechurn 9 Posted December 19, 2022 Posted December 19, 2022 Often times when I am browsing the guide I find myself catching a program half way. Is there a way an easy way to see other showing of that program? I think Windows Media Center had such an ability. It would be nice if you could see when and where the program is on in the future and also schedule it to record (if desired)
Luke 42186 Posted December 19, 2022 Posted December 19, 2022 Hi, we already have this at the bottom of the program detail screen.
codechurn 9 Posted December 20, 2022 Author Posted December 20, 2022 How does one get into t he program detail view from the guide? If I click on the program in the guide I just get a popup with the choices below. If I click on the channel in the guide I get a list of all the programs and then I can select the program and see the detail view. It would be nice to just have that info i the pop-up from the guide. Also, the behavior for identifying other showings is inconsistent. Searching for a show I see this: However, if I go into one of those showings I do not see the other showings.
Luke 42186 Posted December 20, 2022 Posted December 20, 2022 You can't but we need to update that pop-up so that it contains all of the same information as the detail screen.
codechurn 9 Posted December 21, 2022 Author Posted December 21, 2022 Need me to file a bug or a feature request to make this official?
Luke 42186 Posted December 21, 2022 Posted December 21, 2022 28 minutes ago, codechurn said: Need me to file a bug or a feature request to make this official? You've done that by opening this topic. We'll take a look at it. Thanks. 1
