Eigeplackter 93 Posted December 18, 2022 Posted December 18, 2022 I'm running Emby Server (Synology) beta 4.8.0.21 amd somehow statistics are screwed up. As you can see the media qualities aren't correct, where is the data stored that makes appearing "Deutsch" and others in the list ? I checked the *.nfo Files, but there it's not. And I habe no idea how to check .bif files
GrimReaper 4912 Posted December 18, 2022 Posted December 18, 2022 Since you're running beta server it is likely plugin dev haven't updated it yet (or maybe he ain't keeping with the beta versions at all and only focusing on stable and you were just getting lucky on previous beta versions as there were no affecting api changes). @hackthis02 1
Eigeplackter 93 Posted December 18, 2022 Author Posted December 18, 2022 Ah might be, will just have to wait for the next stable I guess. 1
DarWun 357 Posted December 18, 2022 Posted December 18, 2022 (edited) @EigeplackterI can't help with resolving your issue. But I thought I would chime in to say that I updated to Emby Beta 4.8.0.21 on my Synology DS918+ NAS, and I'm not having an issue with the Statistics plug-in. Specifically, there are no unexpected entries in the Media Qualities summary under General Statistics. Edited December 18, 2022 by DarWun 1
Happy2Play 9814 Posted December 18, 2022 Posted December 18, 2022 I don't see this on either beta server either. But dev may need to see a server log after task has run.
Solution seanbuff 1357 Posted December 18, 2022 Solution Posted December 18, 2022 8 hours ago, Eigeplackter said: As you can see the media qualities aren't correct, where is the data stored that makes appearing "Deutsch" and others @Eigeplackter in your case, "Deutsch" is coming from an embedded title in the video file itself. See this as an example... Media Info: Using something like MKVtoolnix to remove the embedded title, refresh metadata, and run Statistics calculation again - you'll find it will be cleared. I think the problem you will have is locating exactly which media file has "Deutsch" embedded in the title (unlike the above example which is easy) 1
Eigeplackter 93 Posted December 18, 2022 Author Posted December 18, 2022 Ahhh I see. Okay, solution sounds like fun for an evening At least I know where it‘s comming from.
seanbuff 1357 Posted December 18, 2022 Posted December 18, 2022 For that second one, open up one of your Die Hard's and scroll down to the media info section to see if one of them has an embedded title.
Eigeplackter 93 Posted December 18, 2022 Author Posted December 18, 2022 Possible, but „Die“ is one german translation for „the“ …. The Untouchables - Die Unbestechlichen The Incredibles - Die Unglaublichen and so on
seanbuff 1357 Posted December 18, 2022 Posted December 18, 2022 1 minute ago, Eigeplackter said: Possible, but „Die“ is one german translation for „the“ …. The Untouchables - Die Unbestechlichen The Incredibles - Die Unglaublichen and so on Haha there was only 1 so I was hoping that wasn't the case. Good luck! 1
Eigeplackter 93 Posted December 18, 2022 Author Posted December 18, 2022 Is there any way to remove those data by batch ? I did those for like 20 files manually with MKVToolnix, it's tiresome.
seanbuff 1357 Posted December 18, 2022 Posted December 18, 2022 3 minutes ago, Eigeplackter said: Is there any way to remove those data by batch ? I did those for like 20 files manually with MKVToolnix, it's tiresome. Create a batch file, insert the following: for /R %%f in (*.mkv) do "mkvpropedit" "%%f" --edit track:v1 --set name="" pause Either explicitly supply the path to 'mkvpropedit' or alternatively add the MKVtoolnix dir to your $PATH environment variable It's recursive, so will go into subfolders. 1
seanbuff 1357 Posted December 18, 2022 Posted December 18, 2022 Might also want to clear out audio track titles while you're at it for /R %%f in (*.mkv) do "mkvpropedit" "%%f" --edit track:v1 --set name="" --edit track:a1 --set name="" pause
Happy2Play 9814 Posted December 18, 2022 Posted December 18, 2022 @hackthis02why would track titles option affect this? But yes enabling this option and running task will show OP results. Setting to Friendly and scanning removes them. 1
Eigeplackter 93 Posted December 18, 2022 Author Posted December 18, 2022 Ok I'll try that overnight, rescan might take a while.
hackthis02 130 Posted December 19, 2022 Posted December 19, 2022 1 hour ago, Happy2Play said: @hackthis02why would track titles option affect this? But yes enabling this option and running task will show OP results. Setting to Friendly and scanning removes them. I don't know. I've never used this option. I'll check it out after the 1st. As for @Eigeplackter If you turn on debug logging. It will list all your shows/movies and what quality they are reporting.
Eigeplackter 93 Posted December 19, 2022 Author Posted December 19, 2022 9 hours ago, Happy2Play said: @hackthis02why would track titles option affect this? But yes enabling this option and running task will show OP results. Setting to Friendly and scanning removes them. I changed settings to user friendly and did a library scan overnight, this morning I did a calculate statistics. No change. Right now im running the batch @seanbufforovided, will report after it's done.
Happy2Play 9814 Posted December 19, 2022 Posted December 19, 2022 (edited) 17 minutes ago, Eigeplackter said: I changed settings to user friendly and did a library scan overnight, this morning I did a calculate statistics. No change. Right now im running the batch @seanbufforovided, will report after it's done. All I did was run the task and it corrected the list. Edited December 19, 2022 by Happy2Play
Eigeplackter 93 Posted December 19, 2022 Author Posted December 19, 2022 13 hours ago, seanbuff said: Create a batch file, insert the following: for /R %%f in (*.mkv) do "mkvpropedit" "%%f" --edit track:v1 --set name="" pause Either explicitly supply the path to 'mkvpropedit' or alternatively add the MKVtoolnix dir to your $PATH environment variable It's recursive, so will go into subfolders. That has done the job ! No more "Deutsch" the rest seems to be in the other library, running batch there too. Thanks @seanbuff 1
