Barbablanca 7 Posted December 17, 2022 Posted December 17, 2022 If I use PotPlayer as the external Player, then what is the path to the media file being played?
Luke 42234 Posted December 17, 2022 Posted December 17, 2022 Hi, are you asking about what potpkayer requires or how to enter it into emby?
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 What I need to know is how do I enter it into emby?
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 8 hours ago, Barbablanca said: What I need to know is how do I enter it into emby?
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 But just typing in "{path}" doesn't work. Doesn't there need to be am environmental variable to point the player to the correct media file?
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 7 minutes ago, Barbablanca said: But just typing in "{path}" doesn't work. Works for me. That is the variable.
Eigeplackter 92 Posted December 17, 2022 Posted December 17, 2022 Same here, even though i put some other variables there too: 1
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 I still get an error message "type Error: cannot read property 'toString' of undefined' and I changed my parameters to what you suggested
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 2 minutes ago, Barbablanca said: I still get an error message "type Error: cannot read property 'toString' of undefined' and I changed my parameters to what you suggested Are you sure you've entered full path to the player (including executable) and not only folders?
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 I entered it as: C:\Program Files\DAUM\PotPlayer\PotPlayerMini64.exe
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 And is that the path in your system? 1
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 Yes. Now the player launches, but I get a message about "failed to start playback. Unable to connect to the requested server"
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 All my media is on local drives. Emby is set up to play internet trailers before the main attraction.
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 1 minute ago, Barbablanca said: All my media is on local drives. Emby is set up to play internet trailers before the main attraction. Then check your firewall settings or disable those internet trailers.
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 I still get the error message even when I skip the trailers and go right to the movie
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 Are you sure you've disabled trailers as PotPlayer shouldn't be trying to connect externally then and you shouldn't be getting "Unable to connect to the requested server" error since you're playing local content?
Barbablanca 7 Posted December 17, 2022 Author Posted December 17, 2022 I disabled Cinema Intros, but the trailers still attempt to load. If I just play the trailer preview, it plays fine
GrimReaper 4893 Posted December 17, 2022 Posted December 17, 2022 1 minute ago, Barbablanca said: I disabled Cinema Intros, but the trailers still attempt to load If you disabled Cinema Intros, trailers should not attempt to play. Are you using some other plugin, like Vantage Point?
Luke 42234 Posted December 18, 2022 Posted December 18, 2022 Did you research the potplayer command line? What did you find? Does it even support the command line arguments in this format?
Barbablanca 7 Posted December 18, 2022 Author Posted December 18, 2022 After all of this I finally managed to get Emby playing files using PotPlayer, BUT it appears that the original media file isn't being played because the Dolby Digital/DTS display isn't being triggered on my receiver which implies that a stream is being played.
Luke 42234 Posted December 18, 2022 Posted December 18, 2022 If you make sure the emby theater machine can directly access the path used in emby server library setup and then it will pass the original file path to the external player.
Solution Barbablanca 7 Posted December 19, 2022 Author Solution Posted December 19, 2022 My bad ...I overlooked the audio settings menu where which formats such as EAC3, DTS, DTS-HD, etc can be set for pass through. Everything working as it should. Thanks for the help. 1
SeasideGR 0 Posted December 18, 2024 Posted December 18, 2024 (edited) Sorry for digging up the thread but i need help if possible. Setup Both Machines Win 11 Pro Emby Server Ryzen 8600G / 32GB RAM 6400 / 1x500GB NVME 8x24TB disks / Emby Server with Emby Premiere HTPC - MPC + MadVR Ryzen 8600G / 32GB RAM 6400 / 1x500 NVME drive / Emby Theater When i put the arguments emby "calls" MPC but the sound is not passed. I see only AAC in the properties of the file being played. On the Theater machine sound formats are enabled for pass through. 3D IS NOT enabled. The Emby external player path must be from the client machine (HTPC) OR from the server ? How the arguments must be etered in which form ? I just want from the Emby Theater GUI the player to 1)Open 2)Start Playing and then close and return to Emby Enviroment. Edited December 18, 2024 by SeasideGR
Luke 42234 Posted December 18, 2024 Posted December 18, 2024 2 minutes ago, SeasideGR said: The Emby external player path must be from the client machine (HTPC) OR from the server ? How the arguments must be etered in which form ? From the client machine. What arguments does MPC require to do what you want? Have you looked into that? 1
