Luke 42310 Posted May 20, 2023 Posted May 20, 2023 2 hours ago, PuffyToesToo said: Is it possible to use some sort of rules as part of Emby itself, or a plugin? For example, online radio stations and even IRL ones mitigate repetition through the use of rules. You can specify that a song can only be played once during any given "x hours/days". It can be applies to artists, albums etc - so is it possible to integrate that into Emby itself? Or an option within shuffle/playlists could include "only play an episode/show/whatever if it hasn't played in "X' amount of time". Maybe with Smart Playlists? Hi, yes smart playlists could have rules like that. 1
PuffyToesToo 348 Posted May 20, 2023 Posted May 20, 2023 19 minutes ago, Luke said: Hi, yes smart playlists could have rules like that. Excellent! Would it be best to leave this here or make it a feature request?
Luke 42310 Posted May 22, 2023 Posted May 22, 2023 On 5/20/2023 at 11:43 AM, PuffyToesToo said: Excellent! Would it be best to leave this here or make it a feature request? Feature request or add to existing one about smart playlists. Thanks ! 1
King Pin 34 Posted May 23, 2023 Author Posted May 23, 2023 I've just moved back over to PLEX for my playlists. I pretty much had enough of watching the same 30 episodes out of a mix of thousands. I put Trailer Park Boys on shuffle this morning (12 seasons). Watched a couple hours worth, shut it off and went out. Came home an hour ago and hit shuffle again and the first two episodes EMBY played were both played this morning. Installed PLEX and so far so good. I much prefer EMBY but 95% of my viewing is playlists at home on different tv's and after years of the same issue I had enough. 1
King Pin 34 Posted March 18, 2024 Author Posted March 18, 2024 I think I found an answer for the issue. Not sure why it works but so far so good after 3 days and no repeats. Instead of adding shows to a playlist I turned them into a Collection. I go to the collection and choose shuffle and as I've said no repeats for 3 days now at least none I have noticed. Also it's shuffling from all the shows not just 3 or 4.
Luke 42310 Posted March 20, 2024 Posted March 20, 2024 On 3/17/2024 at 9:18 PM, King Pin said: I think I found an answer for the issue. Not sure why it works but so far so good after 3 days and no repeats. Instead of adding shows to a playlist I turned them into a Collection. I go to the collection and choose shuffle and as I've said no repeats for 3 days now at least none I have noticed. Also it's shuffling from all the shows not just 3 or 4. Hi, glad to hear it, although fyi the shuffling is the same for collections and playlists.
King Pin 34 Posted March 20, 2024 Author Posted March 20, 2024 25 minutes ago, Luke said: Hi, glad to hear it, although fyi the shuffling is the same for collections and playlists. I figured it would be the same as well but decided to try. Still not one repeat and it's playing from all 19 different shows. Something different must happening. 1
