pwhodges 2033 Posted September 9, 2023 Posted September 9, 2023 You could also try sideloading the current Android app, which is more advanced and is being positioned to take over from the Android TV apps. Paul
Madiator2011 2 Posted September 9, 2023 Posted September 9, 2023 32 minutes ago, pwhodges said: You could also try sideloading the current Android app, which is more advanced and is being positioned to take over from the Android TV apps. Paul Intresting swaping from fire tv to android app worked kinda well and getting direct play now with DTS-HD. Another thing for some reason it fixed my subtitles issues 1 1
Dodgexander 8 Posted October 16, 2023 Posted October 16, 2023 Just wanted to clear up some disinformation out there based on my own testing and the latest update. With the latest Kodi nightly bitstreaming all HD audio formats on the Gen 3 cube works great. Sadly the same is not true outside of Kodi, I've tested various players that use forks of exoplayer like emby and DTS is completely broken. Often it will either only play the core or it will try to play HD and the audio and video will freeze up. In some cases libvlc will work with DTS, DTS: X works fine but DTS-HD has a huge delay. The implementation of TrueHD is also hit or miss outside Kodi unless you use a player with libvlc, not including VLC itself ironically. A lot of players are converting True HD to multi channel PCM. But in Kodi everything is perfect, all DTS and Dolby Formats work including HD Atmos. This completely dismisses the various comments online mentioning the Cube Gen 3 only supports the core DTS track. Certainly there's some work to do by app developers still using libvlc and especially exoplayer but at least there's a working method now. 1
Dodgexander 8 Posted October 18, 2023 Posted October 18, 2023 (edited) Here's the fix for DTS audio posted by the Kodi developer. Does this help Emby devs at all, and if not, how can I help get this fix integrated into libvlc and expolayer? https://forum.kodi.tv/showthread.php?tid=371883&pid=3169276#pid3169276 Edited October 18, 2023 by Dodgexander
Tony B. 38 Posted October 18, 2023 Posted October 18, 2023 As far as I know, this is built into the code now, no reason for other downloads
Luke 42244 Posted October 18, 2023 Posted October 18, 2023 4 hours ago, Tony B. said: As far as I know, this is built into the code now, no reason for other downloads HI, what do you mean exactly?
elshagon 44 Posted November 20, 2023 Posted November 20, 2023 I'm trying to decide whether to get the cube, has this been fixed yet?
Madiator2011 2 Posted November 20, 2023 Posted November 20, 2023 1 minute ago, elshagon said: I'm trying to decide whether to get the cube, has this been fixed yet? Owner of the 4K 3gen Cube everything works fine though use sideloaded android apk and not version from Amazon :)
elshagon 44 Posted November 20, 2023 Posted November 20, 2023 (edited) 31 minutes ago, Madiator2011 said: Owner of the 4K 3gen Cube everything works fine though use sideloaded android apk and not version from Amazon Thanks Edited November 20, 2023 by elshagon
rbjtech 5344 Posted November 20, 2023 Posted November 20, 2023 4 hours ago, Madiator2011 said: Owner of the 4K 3gen Cube everything works fine though use sideloaded android apk and not version from Amazon I have zero issues running the Amazon AndroidTV/FireTV version - which imho, still works smoother than the sideloaded version.
Tony B. 38 Posted November 20, 2023 Posted November 20, 2023 Still no DTS:X Just tested with Jurassic World Dominion. Guess I'll keep using Kodi. They need to ditch the player they are using (Exoplayer). Maybe if all the media servers dump them, they will start getting their heads out of their ass.
