bmflagg 21 Posted December 13, 2022 Posted December 13, 2022 (edited) Synology DS1817+ Emby was running on it, but I moved the NAS to another IP and renamed it. (Reorganizing my setups) Started Emby and nothing works - Not even manage server loads.. Everything is blank.. see attached... Uninstalled Emby.. Reinstalled latest version - DISM 7 v7.4.10 . ( Here ) It loads up like it was never uninstalled, just like the attachment. How do I get emby to think it's a new install and reinitialize clean? on a side note.. installed emby on my QNAP Nas, and was unable to access the libraries on the synology NAS...(no place to put authentication while mapping library folders) The only recourse I can think of is reinitialize the nas... hence restore everything... - absolutely the last resort! Edited December 13, 2022 by bmflagg
Luke 42242 Posted December 20, 2022 Posted December 20, 2022 hi @bmflagg are you still having an issue with this? Please try running a library scan and then attach the emby server log. How to Report a Problem Thanks !
Happy2Play 9811 Posted December 20, 2022 Posted December 20, 2022 On 12/12/2022 at 6:40 PM, bmflagg said: Uninstalled Emby.. Reinstalled latest version - DISM 7 v7.4.10 . ( Here ) It loads up like it was never uninstalled, just like the attachment. How do I get emby to think it's a new install and reinitialize clean? @LukeDoes Synology not have uninstall everything? Looks like possibly a cache issue but probably need server log and possibly console log depending on client used. The image above does not make since either as the URL is for Dashboard but in on Home. @cayarsdo know the steps to remove program data on Synology?
Solution Carlo 4561 Posted December 21, 2022 Solution Posted December 21, 2022 SSH into box as normal user then go super using "sudo -i" What you have to do is remove the directory and contents below: /volume1/@appdata/EmbyServer That assumes it was installed on volume1. 1
bmflagg 21 Posted December 21, 2022 Author Posted December 21, 2022 Thanks Cayars for helping out a fellow Rush fan! 1
