sross44 434 Posted December 13, 2022 Posted December 13, 2022 I've got Emby running on a Windows machine. I'm trying to move away from Cloudfare for SSL because of the updated TOS. I feel like I'm lost with Nginx though. Anyone willing to help me out via TeamViewer to get it up and running? I can either do a straight install of Nginx or run it in Docker... whatever is best. Just need some help and guidance.
Q-Droid 1002 Posted December 13, 2022 Posted December 13, 2022 Someone will recommend, and I would agree, that if you're getting started then Caddy would be much easier and just as good. 2
sross44 434 Posted December 13, 2022 Author Posted December 13, 2022 4 minutes ago, Q-Droid said: Someone will recommend, and I would agree, that if you're getting started then Caddy would be much easier and just as good. Well if that's the case then I'm definitely down for trying Caddy. Any suggestions or pointers would be highly recommended.
Q-Droid 1002 Posted December 13, 2022 Posted December 13, 2022 My last questions for the night are what do you have now with Cloudflare and what do you want to have without them? Do you plan to keep CF for domain/DNS?
sross44 434 Posted December 13, 2022 Author Posted December 13, 2022 Just now, Q-Droid said: My last questions for the night are what do you have now with Cloudflare and what do you want to have without them? Do you plan to keep CF for domain/DNS? I want to eliminate using Cloudfare since their TOS has changed and now they're saying no video. I guess this really isn't a big deal? Some don't seem to be bothered by this... others seem to be getting banned from Cloudfare lol.
seanbuff 1353 Posted December 13, 2022 Posted December 13, 2022 1 hour ago, sross44 said: Well if that's the case then I'm definitely down for trying Caddy. Any suggestions or pointers would be highly recommended. @pwhodges provides a very good guide here: https://emby.media/community/index.php?/topic/84777-caddy-v2-update-and-warning/&do=findComment&comment=879750 You basically just need to: install the default Caddy v2 package configure basic config file named 'Caddyfile' (see below) port forward 80 and 443 in your router to your Caddy host update Emby with your Public HTTP/HTTPS ports, external domain, and Secure connection mode = handled by reverse proxy run Caddy Basic Caddy config file would look like this: { email myname@email.com } media.mydomain.net { reverse_proxy <emby_host_ip>:8096 } Not much else to it, see how you go and let us know if and where you get stuck. 1
Q-Droid 1002 Posted December 13, 2022 Posted December 13, 2022 8 hours ago, sross44 said: I want to eliminate using Cloudfare since their TOS has changed and now they're saying no video. I guess this really isn't a big deal? Some don't seem to be bothered by this... others seem to be getting banned from Cloudfare lol. Right. What I wanted to know was if you're using CF for application services (SSL,DDoS, etc) including DNS for your domain and if you plan to keep your domain with CF but run your own reverse proxy as a direct entry point for Emby. You'll need to keep your domain somewhere and continue whichever IP updater you already use. The rest, as posted above, is pretty straight forward.
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 On 12/12/2022 at 11:46 PM, seanbuff said: @pwhodges provides a very good guide here: https://emby.media/community/index.php?/topic/84777-caddy-v2-update-and-warning/&do=findComment&comment=879750 You basically just need to: install the default Caddy v2 package configure basic config file named 'Caddyfile' (see below) port forward 80 and 443 in your router to your Caddy host update Emby with your Public HTTP/HTTPS ports, external domain, and Secure connection mode = handled by reverse proxy run Caddy Basic Caddy config file would look like this: { email myname@email.com } media.mydomain.net { reverse_proxy <emby_host_ip>:8096 } Not much else to it, see how you go and let us know if and where you get stuck. When i tris this, the CMD window shows a lot of info but specially i see "could not get certificate from issue"
guunter 49 Posted August 9, 2024 Posted August 9, 2024 14 minutes ago, mjroberts said: When i tris this, the CMD window shows a lot of info but specially i see "could not get certificate from issue" I've never used the email syntax like in the comment. Try it without that and see if it works.
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 10 minutes ago, guunter said: I've never used the email syntax like in the comment. Try it without that and see if it works. Thanks for the reply I removed the email and ran it again with i think the same error, see below **not i substituted my real domain name for "mydomain.com" Looks like my Domain site ionos.ca is refusing access, do i need a username/password or something? Quote 2024/08/09 15:20:48.925 ←[34mINFO←[0m using adjacent Caddyfile 2024/08/09 15:20:48.927 ←[34mINFO←[0m adapted config to JSON {"adapter": "caddyfile"} 2024/08/09 15:20:48.929 ←[33mWARN←[0m Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 1} 2024/08/09 15:20:48.940 ←[34mINFO←[0m admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]} 2024/08/09 15:20:48.942 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc00064c280"} 2024/08/09 15:20:48.942 ←[34mINFO←[0m http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443} 2024/08/09 15:20:48.943 ←[34mINFO←[0m http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"} 2024/08/09 15:20:48.944 ←[34mINFO←[0m http enabling HTTP/3 listener {"addr": ":443"} 2024/08/09 15:20:48.944 ←[34mINFO←[0m http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]} 2024/08/09 15:20:48.944 ←[34mINFO←[0m http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]} 2024/08/09 15:20:48.945 ←[34mINFO←[0m http enabling automatic TLS certificate management {"domains": ["mydomain.com"]} 2024/08/09 15:20:48.946 ←[34mINFO←[0m autosaved config (load with --resume flag) {"file": "C:\\Users\\PLEX_SERVER\\AppData\\Roaming\\Caddy\\autosave.json"} 2024/08/09 15:20:48.946 ←[34mINFO←[0m serving initial configuration 2024/08/09 15:20:48.962 ←[34mINFO←[0m tls.obtain acquiring lock {"identifier": "mydomain.com"} 2024/08/09 15:20:48.963 ←[34mINFO←[0m [INFO][FileStorage:C:\Users\PLEX_SERVER\AppData\Roaming\Caddy] Lock for 'issue_cert_mydomain.com' is stale (created: 2024-08-09 10:51:28.3364281 -0400 EDT, last update: 2024-08-09 11:18:47.5566867 -0400 EDT); removing then retrying: C:\Users\PLEX_SERVER\AppData\Roaming\Caddy\locks\issue_cert_mydomain.com.lock 2024/08/09 15:20:48.966 ←[34mINFO←[0m tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:C:\\Users\\PLEX_SERVER\\AppData\\Roaming\\Caddy", "instance": "274ef569-0dad-4625-b5e6-85665157c6c6", "try_again": "2024/08/10 15:20:48.966", "try_again_in": 86400} 2024/08/09 15:20:48.968 ←[34mINFO←[0m tls.obtain lock acquired {"identifier": "mydomain.com"} 2024/08/09 15:20:48.968 ←[34mINFO←[0m tls.obtain obtaining certificate {"identifier": "mydomain.com"} 2024/08/09 15:20:48.969 ←[34mINFO←[0m tls finished cleaning storage units 2024/08/09 15:20:48.982 ←[34mINFO←[0m http waiting on internal rate limiter {"identifiers": ["mydomain.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "mydomain@gmail.com"} 2024/08/09 15:20:48.982 ←[34mINFO←[0m http done waiting on internal rate limiter {"identifiers": ["mydomain.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "mydomain@gmail.com"} 2024/08/09 15:20:48.982 ←[34mINFO←[0m http using ACME account {"account_id": "https://acme-v02.api.letsencrypt.org/acme/acct/1882600666", "account_contact": ["mailto:mydomain@gmail.com"]} 2024/08/09 15:20:49.635 ←[34mINFO←[0m http.acme_client trying to solve challenge {"identifier": "mydomain.com", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"} 2024/08/09 15:20:49.902 ←[34mINFO←[0m tls served key authentication certificate {"server_name": "mydomain.com", "challenge": "tls-alpn-01", "remote": "23.178.112.214:35939", "distributed": false} 2024/08/09 15:20:50.704 ←[31mERROR←[0m http.acme_client challenge failed {"identifier": "mydomain.com", "challenge_type": "tls-alpn-01", "problem": {"type": "urn:ietf:params:acme:error:tls", "title": "", "detail": "During secondary validation: 74.208.236.77: remote error: tls: internal error", "instance": "", "subproblems": []}} 2024/08/09 15:20:50.704 ←[31mERROR←[0m http.acme_client validating authorization {"identifier": "mydomain.com", "problem": {"type": "urn:ietf:params:acme:error:tls", "title": "", "detail": "During secondary validation: 74.208.236.77: remote error: tls: internal error", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/1882600666/294815152066", "attempt": 1, "max_attempts": 3} 2024/08/09 15:20:52.068 ←[34mINFO←[0m http.acme_client trying to solve challenge {"identifier": "mydomain.com", "challenge_type": "http-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"} 2024/08/09 15:20:53.211 ←[31mERROR←[0m http.acme_client challenge failed {"identifier": "mydomain.com", "challenge_type": "http-01", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "2607:f1c0:100f:f000::200: Invalid response from http://mydomain.com/.well-known/acme-challenge/7sHoXh6kY71k_uPZNM5S7r77W2KyDlHg3epWdnFTY5Q: 204", "instance": "", "subproblems": []}} 2024/08/09 15:20:53.211 ←[31mERROR←[0m http.acme_client validating authorization {"identifier": "mydomain.com", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "2607:f1c0:100f:f000::200: Invalid response from http://mydomain.com/.well-known/acme-challenge/7sHoXh6kY71k_uPZNM5S7r77W2KyDlHg3epWdnFTY5Q: 204", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/1882600666/294815158646", "attempt": 2, "max_attempts": 3} 2024/08/09 15:20:53.216 ←[31mERROR←[0m tls.obtain could not get certificate from issuer {"identifier": "mydomain.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "HTTP 403 urn:ietf:params:acme:error:unauthorized - 2607:f1c0:100f:f000::200: Invalid response from http://mydomain.com/.well-known/acme-challenge/7sHoXh6kY71k_uPZNM5S7r77W2KyDlHg3epWdnFTY5Q: 204"} 2024/08/09 15:20:53.217 ←[31mERROR←[0m tls.obtain will retry {"error": "[mydomain.com] Obtain: [mydomain.com] solving challenge: mydomain.com: [mydomain.com] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - 2607:f1c0:100f:f000::200: Invalid response from http://mydomain.com/.well-known/acme-challenge/7sHoXh6kY71k_uPZNM5S7r77W2KyDlHg3epWdnFTY5Q: 204 (ca=https://acme-v02.api.letsencrypt.org/directory)", "attempt": 1, "retrying_in": 60, "elapsed": 4.2492656, "max_duration": 2592000}
guunter 49 Posted August 9, 2024 Posted August 9, 2024 1 minute ago, mjroberts said: Thanks for the reply I removed the email and ran it again with i think the same error, see below **not i substituted my real domain name for "mydomain.com" Looks like my Domain site ionos.ca is refusing access, do i need a username/password or something? Can you post your CaddyFile and redact important info? I'm linux though but i'll try to see if i see something weird.
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 12 minutes ago, guunter said: Can you post your CaddyFile and redact important info? I'm linux though but i'll try to see if i see something weird. I am using the file below and i downlaoded Caddy today so the latest version that downloads as an .exe file not a zip file Quote { email myname@email.com } media.mydomain.net { reverse_proxy <emby_host_ip>:8096 }
guunter 49 Posted August 9, 2024 Posted August 9, 2024 (edited) 5 minutes ago, mjroberts said: I am using the file below and i downlaoded Caddy today so the latest version that downloads as an .exe file not a zip file That's not how it should look. It should be... emby.domain.com { reverse_proxy 192.168.0.33:8096 } Can you post the DL link you used? Also did you allow Caddy through the Windows Firewall? Edited August 9, 2024 by guunter
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 7 minutes ago, guunter said: That's not how it should look. It should be... emby.domain.com { reverse_proxy 192.168.0.33:8096 } Can you post the DL link you used? Also did you allow Caddy through the Windows Firewall? Just so i am clear, if my domain is "familyserver.com" then would it be familyserver.com { or emy.familyserver.com { ? i downloaded from Download Caddy (caddyserver.com) yes Caddy.exe is allowed through the firewall
guunter 49 Posted August 9, 2024 Posted August 9, 2024 1 minute ago, mjroberts said: Just so i am clear, if my domain is "familyserver.com" then would it be familyserver.com { or emy.familyserver.com { ? i downloaded from Download Caddy (caddyserver.com) yes Caddy.exe is allowed through the firewall The way I have mine configured i use a subdomain. I created an A record for my website on Cloudflare for example adding "emby". I also use plex and jellyfin on my domain so i use subdomains to separate them.
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 4 minutes ago, guunter said: The way I have mine configured i use a subdomain. I created an A record for my website on Cloudflare for example adding "emby". I also use plex and jellyfin on my domain so i use subdomains to separate them. ok i have a domain through ionos.ca but not using a subdomain as this is the only service i'll be using it for I have the A record updated and i can use my domain right now via http and connect to my emby server but obviously i wants SSL What exactly do i need to do? Is there another software or provider i need between Caddy and my Domain register? I changed my file in Caddy to match yours and the output is this Quote Microsoft Windows [Version 10.0.19045.4651] (c) Microsoft Corporation. All rights reserved. C:\Windows\system32>cd\ C:\>cd caddy C:\Caddy>caddy run 2024/08/09 15:59:11.379 ←[34mINFO←[0m using adjacent Caddyfile 2024/08/09 15:59:11.381 ←[34mINFO←[0m adapted config to JSON {"adapter": "caddyfile"} 2024/08/09 15:59:11.381 ←[33mWARN←[0m Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 1} 2024/08/09 15:59:11.390 ←[34mINFO←[0m admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]} 2024/08/09 15:59:11.390 ←[34mINFO←[0m http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443} 2024/08/09 15:59:11.390 ←[34mINFO←[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc0006f7780"} 2024/08/09 15:59:11.390 ←[34mINFO←[0m http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"} 2024/08/09 15:59:11.391 ←[34mINFO←[0m http enabling HTTP/3 listener {"addr": ":443"} 2024/08/09 15:59:11.392 ←[34mINFO←[0m http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]} 2024/08/09 15:59:11.392 ←[34mINFO←[0m http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]} 2024/08/09 15:59:11.392 ←[34mINFO←[0m http enabling automatic TLS certificate management {"domains": ["mydomainname.com"]} 2024/08/09 15:59:11.393 ←[34mINFO←[0m autosaved config (load with --resume flag) {"file": "C:\\Users\\PLEX_SERVER\\AppData\\Roaming\\Caddy\\autosave.json"} 2024/08/09 15:59:11.393 ←[34mINFO←[0m serving initial configuration 2024/08/09 15:59:11.395 ←[34mINFO←[0m tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:C:\\Users\\PLEX_SERVER\\AppData\\Roaming\\Caddy", "instance": "274ef569-0dad-4625-b5e6-85665157c6c6", "try_again": "2024/08/10 15:59:11.395", "try_again_in": 86400} 2024/08/09 15:59:11.403 ←[34mINFO←[0m tls finished cleaning storage units 2024/08/09 15:59:11.404 ←[34mINFO←[0m tls.obtain acquiring lock {"identifier": "mydomainname.com"} 2024/08/09 15:59:11.407 ←[34mINFO←[0m [INFO][FileStorage:C:\Users\PLEX_SERVER\AppData\Roaming\Caddy] Lock for 'issue_cert_mydomainname.com' is stale (created: 2024-08-09 11:28:39.1295226 -0400 EDT, last update: 2024-08-09 11:35:45.2853222 -0400 EDT); removing then retrying: C:\Users\PLEX_SERVER\AppData\Roaming\Caddy\locks\issue_cert_mydomainname.com.lock 2024/08/09 15:59:11.411 ←[34mINFO←[0m tls.obtain lock acquired {"identifier": "mydomainname.com"} 2024/08/09 15:59:11.412 ←[34mINFO←[0m tls.obtain obtaining certificate {"identifier": "mydomainname.com"} 2024/08/09 15:59:11.415 ←[34mINFO←[0m http waiting on internal rate limiter {"identifiers": ["mydomainname.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "mydomainname@gmail.com"} 2024/08/09 15:59:11.415 ←[34mINFO←[0m http done waiting on internal rate limiter {"identifiers": ["mydomainname.com"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": "mydomainname@gmail.com"} 2024/08/09 15:59:11.417 ←[34mINFO←[0m http using ACME account {"account_id": "https://acme-v02.api.letsencrypt.org/acme/acct/1882600666", "account_contact": ["mailto:mydomainname@gmail.com"]} 2024/08/09 15:59:12.018 ←[34mINFO←[0m http.acme_client trying to solve challenge {"identifier": "mydomainname.com", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"} 2024/08/09 15:59:12.449 ←[31mERROR←[0m http.acme_client challenge failed {"identifier": "mydomainname.com", "challenge_type": "tls-alpn-01", "problem": {"type": "urn:ietf:params:acme:error:connection", "title": "", "detail": "74.208.236.77: Error getting validation data", "instance": "", "subproblems": []}} 2024/08/09 15:59:12.449 ←[31mERROR←[0m http.acme_client validating authorization {"identifier": "mydomainname.com", "problem": {"type": "urn:ietf:params:acme:error:connection", "title": "", "detail": "74.208.236.77: Error getting validation data", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/1882600666/294822127216", "attempt": 1, "max_attempts": 3} 2024/08/09 15:59:13.686 ←[34mINFO←[0m http.acme_client trying to solve challenge {"identifier": "mydomainname.com", "challenge_type": "http-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"} 2024/08/09 15:59:14.147 ←[31mERROR←[0m http.acme_client challenge failed {"identifier": "mydomainname.com", "challenge_type": "http-01", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "2607:f1c0:100f:f000::200: Invalid response from http://mydomainname.com/.well-known/acme-challenge/aW1Gx8WPoEAXSn566KU5jTyNdxZjUguGydyOZd9VbtY: 204", "instance": "", "subproblems": []}} 2024/08/09 15:59:14.147 ←[31mERROR←[0m http.acme_client validating authorization {"identifier": "mydomainname.com", "problem": {"type": "urn:ietf:params:acme:error:unauthorized", "title": "", "detail": "2607:f1c0:100f:f000::200: Invalid response from http://mydomainname.com/.well-known/acme-challenge/aW1Gx8WPoEAXSn566KU5jTyNdxZjUguGydyOZd9VbtY: 204", "instance": "", "subproblems": []}, "order": "https://acme-v02.api.letsencrypt.org/acme/order/1882600666/294822132086", "attempt": 2, "max_attempts": 3} 2024/08/09 15:59:14.152 ←[31mERROR←[0m tls.obtain could not get certificate from issuer {"identifier": "mydomainname.com", "issuer": "acme-v02.api.letsencrypt.org-directory", "error": "HTTP 403 urn:ietf:params:acme:error:unauthorized - 2607:f1c0:100f:f000::200: Invalid response from http://mydomainname.com/.well-known/acme-challenge/aW1Gx8WPoEAXSn566KU5jTyNdxZjUguGydyOZd9VbtY: 204"} 2024/08/09 15:59:14.153 ←[31mERROR←[0m tls.obtain will retry {"error": "[mydomainname.com] Obtain: [mydomainname.com] solving challenge: mydomainname.com: [mydomainname.com] authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - 2607:f1c0:100f:f000::200: Invalid response from http://mydomainname.com/.well-known/acme-challenge/aW1Gx8WPoEAXSn566KU5jTyNdxZjUguGydyOZd9VbtY: 204 (ca=https://acme-v02.api.letsencrypt.org/directory)", "attempt": 1, "retrying_in": 60, "elapsed": 2.7409079, "max_duration": 2592000}
guunter 49 Posted August 9, 2024 Posted August 9, 2024 5 minutes ago, mjroberts said: ok i have a domain through ionos.ca but not using a subdomain as this is the only service i'll be using it for I have the A record updated and i can use my domain right now via http and connect to my emby server but obviously i wants SSL What exactly do i need to do? Is there another software or provider i need between Caddy and my Domain register? I changed my file in Caddy to match yours and the output is this It should all be done automatically. So you're saying if you do https://domain.com you get a 443 error?
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 2 minutes ago, guunter said: It should all be done automatically. So you're saying if you do https://domain.com you get a 443 error? I have to use http://www.mydomainname.com:8096/ and i can access emby if i try to use SSL i try http://www.mydomainname.com:8920/ and i get The connection for this site is not secure mydomainname.com sent an invalid response. ERR_SSL_PROTOCOL_ERROR
guunter 49 Posted August 9, 2024 Posted August 9, 2024 4 minutes ago, mjroberts said: I have to use http://www.mydomainname.com:8096/ and i can access emby if i try to use SSL i try http://www.mydomainname.com:8920/ and i get The connection for this site is not secure mydomainname.com sent an invalid response. ERR_SSL_PROTOCOL_ERROR If you're properly reverse proxied you do not need the ports. It should be https://mydomain.com . port 8920 is only if upload your own cert to emby. Does your site work without adding the ports at all?
HairyBizRat 21 Posted August 9, 2024 Posted August 9, 2024 2 minutes ago, guunter said: If you're properly reverse proxied you do not need the ports. It should be https://mydomain.com . port 8920 is only if upload your own cert to emby. Does your site work without adding the ports at all? No, it only works with ports
guunter 49 Posted August 9, 2024 Posted August 9, 2024 Just now, mjroberts said: No, it only works with ports On your router did you by chance port forward 8096 and 8920? When you use a reverse proxy the only port you want open on your router is port 443. That way only port 443 is exposed to the world and the reverse proxy will handle the internal ports and serve them all as 443 externally. 1
