BurntTech 6 Posted December 12, 2022 Posted December 12, 2022 I have NUC8 using integrated graphics hooked up to the receiver then to a S95B Samsung. This used to work before but i'll be honest i'm not sure if this stopped working with the new TV was added or not. Movies like harry potter using trueHD 7.1 works just fine using direct play. But trying any movie with AC3 using direct play has zero audio. With direct play there isn't any logs like there is for transcoding, I'm guessing I need debug logging? While troubleshooting I noticed that under stats for nerds that audio was transferring 0kbps. I tried some tricks like rewinding or fastforwarding. Enable audio passtrough for AC3 Changing windows audio output mode from 7.1 down to 5.1 down to stereo Playing from same movie from the webplayer on the NUC8 works with AC3
Luke 42237 Posted December 13, 2022 Posted December 13, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
BurntTech 6 Posted December 13, 2022 Author Posted December 13, 2022 3.0.19 after the upgrade it worked playing test movie once after restart it didnt play audio again included the theater log since since this is a directplay issue. I didn't anything great in those logs. I also attached an image showing the 0 bitrate of audio Server Version:4.7.10.0 Theater Versions 3.0.19 theater-63806542153.txt
Luke 42237 Posted December 14, 2022 Posted December 14, 2022 If you disable ac3 passthrough, how does that compare?
BurntTech 6 Posted December 14, 2022 Author Posted December 14, 2022 Small update since i'm starting to lose track of what is doing what. I enabled HDR in windows and broke audio for previously working 5.1/7.1 movies Switched from Direct mode to auto surround on the receiver. This seems to allow AC3(Also now the 5.1/7.1 broken audio too) audio to work only if you rewind or fastforward. Sidenote: Receiver has to click its relay each time passthrough changes is sent. Not sure if this delay is a reason why?
Guest Posted December 14, 2022 Posted December 14, 2022 I noticed that you aren't using hardware acceleration. In the video settings try setting video output to gpu-next and hardware acceleration to auto. Does the audio work correctly, then?
BurntTech 6 Posted December 14, 2022 Author Posted December 14, 2022 (edited) no the audio has been a complete pain and getting out of sync. I tried gpu and gpu-next with forced hardware acceleration and auto and it seems to get choppy still. I'm wondering if this audio related since it seems to change when display syncing VIDEO video output = auto/gpu/gpu-next/libmpv - same choppy behavior hardware acceleration = auto and auto copy back output range = auto deinterlace: off - poor performance audio delay = 0 audio delay23-25 = 0 enable refeshrate switching = yes perfered refresh rates = blank enable video display syncing = auto (I tried using resample and it seemed to get worse but the audio worked without rewinding first!?) direct3d = off interpolation = off AUDIO speaker layout = auto or 7.1 passthroughs tried them on and off exclusive = off upmix music = on It was so bad we ended up doing vlc player last night Edited December 14, 2022 by BurntTech adding audio
Guest Posted December 15, 2022 Posted December 15, 2022 This is sounding like a driver issue. What OS, and when was the gpu driver last updated?
BurntTech 6 Posted December 15, 2022 Author Posted December 15, 2022 Windows 10 and the GPU drivers I had just updated with intel driver package for HDMI GPU and HDMI audio drivers
Guest Posted December 17, 2022 Posted December 17, 2022 @BurntTech do you know how to generate an mpv log? If you do, can you repeat the error and attach the log? If you don't, take a look at this link and create an mpv.conf. Add the line for logging, including the text file name and extension. EXAMPLE: log-file="C:\Users\username\Documents\mpv logs\log.txt" Play the video once, and attach the log.
