SPowe 0 Posted December 4, 2022 Posted December 4, 2022 Hi, i am using an exip 418 fw 1.0.9 from kathrein with the below m3u list (https://www.satip.info/resources/channel-lists/). If i want to playback a tv channel i get the following error: I disabled transcoding, as my server with the emby jail has not much computing power. I get following error in the log: 2022-12-04 23:17:28.376 Error MediaSourceManager: Error probing live tv stream *** Error Report *** Version: 4.7.10.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.dll -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server Operating system: FreeBSD 13.1-RELEASE-p2 FreeBSD 13.1-RELEASE-p2 n245412-484f039b1d0 TRUENAS Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: usr/local/lib/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/db/emby-server Application path: /usr/local/lib/emby-server/system System.Exception: System.Exception: ffprobe failed for "rtsp://192.168.8.70/?src=1&freq=12188&pol=h&ro=0.35&msys=dvbs&mtype=qpsk&plts=off&sr=27500&fec=34&pids=0,17,18,166,128,46,68" - streams and format are both null: { } ffprobe version 5.0.0-emby_2022_05_07-spc Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303) [rtsp @ 0x8084b3000] method DESCRIBE failed: 404 Not Found rtsp://192.168.8.70/?src=1&freq=12188&pol=h&ro=0.35&msys=dvbs&mtype=qpsk&plts=off&sr=27500&fec=34&pids=0,17,18,166,128,46,68: Server returned 404 Not Found at Emby.Server.MediaEncoding.Probing.MediaProbeManager.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, String userAgent, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, ReadOnlyMemory`1 cacheKey, Boolean addProbeDelay, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() But if i am opening the link where emby says its an 404 err "rtsp://192.168.8.70/?src=1&freq=12188&pol=h&ro=0.35&msys=dvbs&mtype=qpsk&plts=off&sr=27500&fec=34&pids=0,17,18,166,128,46,68" in vlc, the stream plays asap without any problems. You`ve gaot any ideas how to solve this ? Cheers, Sascha embyserver.txt ASTRA_19_2E.m3u
SPowe 0 Posted December 4, 2022 Author Posted December 4, 2022 and the same gui error happens with enabled transcoding with another log entry: 2022-12-04 23:51:33.370 Info App: ProcessRun 'StreamTranscode 4fb6e2' Execute: /usr/local/lib/emby-server/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/var/db/emby-server/logs/ffmpeg-transcode-4fb6e27c-a20b-4c05-8490-3dc4e13f4638_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -stream_loop -1 -i "rtsp://192.168.8.70/?src=1&freq=11362&pol=h&ro=0.35&msys=dvbs2&mtype=8psk&plts=on&sr=22000&fec=23&pids=0,17,18,6100,6110,6120,6130" -filter_complex "[v:0]yadif@f1=mode=send_frame:parity=auto:deint=all,format@f2=pix_fmts=yuv420p[f2_out0]" -map [f2_out0] -map a:0 -sn -c:v:0 libx264 -maxrate:v:0 10000000 -bufsize:v:0 20000000 -pix_fmt:v:0 yuv420p -force_key_frames:v:0 "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -preset:v:0 veryfast -profile:v:0 high -level:v:0 3.1 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/var/db/emby-server/transcoding-temp/411F91/411F91.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_list_entry_prefix hls/411F91/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/db/emby-server/transcoding-temp/411F91/411F91_%d.ts" 2022-12-04 23:51:33.385 Info App: AppendExtraLogData - Read graph file: /var/db/emby-server/logs/ffmpeg-transcode-4fb6e27c-a20b-4c05-8490-3dc4e13f4638_1graph.txt 2022-12-04 23:51:33.385 Info App: AppendExtraLogData - Deserialized GraphData fileStream: 314.000 bytes Graph Count: 1 2022-12-04 23:51:33.385 Info App: AppendExtraLogData - File Deleted 2022-12-04 23:51:33.386 Info App: ProcessRun 'StreamTranscode 4fb6e2' Process exited with code 1 - Failed 2022-12-04 23:51:33.424 Error Server: Error processing request *** Error Report *** Version: 4.7.10.0 Command line: /usr/local/lib/emby-server/system/EmbyServer.dll -os freebsd -ffdetect /usr/local/lib/emby-server/bin/ffdetect -ffmpeg /usr/local/lib/emby-server/bin/ffmpeg -ffprobe /usr/local/lib/emby-server/bin/ffprobe -programdata /var/db/emby-server Operating system: FreeBSD 13.1-RELEASE-p2 FreeBSD 13.1-RELEASE-p2 n245412-484f039b1d0 TRUENAS Framework: .NET 6.0.5 OS/Process: x64/x64 Runtime: usr/local/lib/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/db/emby-server Application path: /usr/local/lib/emby-server/system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationToken cancellationToken, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() embyserver.txt
SPowe 0 Posted December 7, 2022 Author Posted December 7, 2022 (edited) Any help is appreciated. I am using the stable container. Does a switch to unstable emby on truenas help? Edited December 7, 2022 by SPowe
SPowe 0 Posted December 9, 2022 Author Posted December 9, 2022 Hi, i am trying to get LiveTV with an EXIP 418 from Kathrein working with emby. I tried alot, nothing really helped. But out of knowhere i got it one time working. I attached the emby log and 2 ffmpeg logs (no transcoding). As you can see, my lucky punch was logged in ffmpeg-transcode-c235984d-9d8a-4e6c-b8ad-65638820a5ae_1: the LiveTV Stream played ONCE in my Chrome Browser. And it took at least 30 seconds until it started - but it started. I tried it once again (switch to another channel an back) and i get the usual behaviour again (2nd ffmpeg logfile), which happens 99% of the time: stream cannot be played: Please give me some hints, how to make LiveTV viewing possible, reliable and switching faster. VLC needs 2 seconds to start the stream (url copied from ffmpeg logs). Kind Regards Sascha ffmpeg-transcode-a18ac3fc-ab59-4352-9b19-c853fe957ad0_1.txt ffmpeg-transcode-c235984d-9d8a-4e6c-b8ad-65638820a5ae_1.txt embyserver.txt
Luke 42242 Posted December 9, 2022 Posted December 9, 2022 Hi, does the exip only support rtsp output or does it have options for other protocols?
samsung2100 21 Posted December 9, 2022 Posted December 9, 2022 Try the channels I sent you with the guide data as well and let me know if it plays fine for you, please do not post that list in main forum thanks. 1
SPowe 0 Posted December 10, 2022 Author Posted December 10, 2022 16 hours ago, Luke said: Hi, does the exip only support rtsp output or does it have options for other protocols? Hi Luke, i asked the vendor - waiting for an qualified answer. The portscan on the device revealed port 80, 111 (rpcbind) and 554 (rtsp) are open. The webfrontend lets me setup only lnb and major network parameters - nothing ts stream specific. Cheers Sascha
Luke 42242 Posted December 13, 2022 Posted December 13, 2022 On 12/10/2022 at 6:49 AM, SPowe said: Hi Luke, i asked the vendor - waiting for an qualified answer. The portscan on the device revealed port 80, 111 (rpcbind) and 554 (rtsp) are open. The webfrontend lets me setup only lnb and major network parameters - nothing ts stream specific. Cheers Sascha That would be great, let us know what you find. Thanks.
ErikaJ 65 Posted December 14, 2022 Posted December 14, 2022 Good Day, I had a similar problem a few months back and it was because my VPN was set to a US area. I then changed it to a non-US area, and it is still working fine. Don't know if that is your issue as well but I just thought I would put it out there. Cheers!!! 1
SPowe 0 Posted March 16, 2023 Author Posted March 16, 2023 So i started again trying to get it work on a truenas scale emby container (the "official" version, not truecharts). Now i got an Octopus NET SL SX8, which exports a not "so well formed"-m3u. But i managed to get a testchannel recognized by emby. And again, it failed streaming. I tested around and found one strange behaviour, which should give a hint: I can ping the octopusnet from the docker-container`s shell. I try to use ffprobe from the command line in the docker container. And i get a timeout/error after >30 seconds - thats the same duration like emby to get an error msg: / # ffprobe "rtsp://octopusnet:554/?src=1&freq=11347&pol=v&msys=dvbs2&sr=22000&pids=0,16,17,18,20,6500,6510,6520,6521,6522,6523,6531,6530" ffprobe version 5.0.0-emby_2022_05_27-u1 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 8.3.0 (crosstool-NG 1.24.0) Server returned 4XX Client Error, but not one of 40{0,1,3,4} If i am using this on my windows host i get a fast answer: ffprobe.exe "rtsp://octopusnet:554/?src=1&freq=11347&pol=v&msys=dvbs2&sr=22000&pids=0,16,17,18,20,6500,6510,6520,6521,6522,6523,6531,6530" ffprobe version 2022-01-06-git-2b541b8c1d-full_build-www.gyan.dev Copyright (c) 2007-2022 the FFmpeg developers built with gcc 11.2.0 (Rev5, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 57. 18.100 / 57. 18.100 libavcodec 59. 20.100 / 59. 20.100 libavformat 59. 17.100 / 59. 17.100 libavdevice 59. 5.100 / 59. 5.100 libavfilter 8. 25.100 / 8. 25.100 libswscale 6. 5.100 / 6. 5.100 libswresample 4. 4.100 / 4. 4.100 libpostproc 56. 4.100 / 56. 4.100 [rtsp @ 000001f71d63f700] Packet corrupt (stream = 0, dts = 3420603558). [NULL @ 000001f71d690e00] non-existing SPS 0 referenced in buffering period [.....] [h264 @ 000001f71d690e00] no frame! [h264 @ 000001f71d690e00] Increasing reorder buffer to 2 [rtsp @ 000001f71d63f700] Could not find codec parameters for stream 8 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options Input #0, rtsp, from 'rtsp://octopusnet:554/?src=1&freq=11347&pol=v&msys=dvbs2&sr=22000&pids=0,16,17,18,20,6500,6510,6520,6521,6522,6523,6531,6530': Metadata: title : MPEG TS Duration: N/A, start: 38006.306200, bitrate: N/A Program 11150 Metadata: service_name : 3sat HD service_provider: ZDFvision Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn Stream #0:3(deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 256 kb/s Stream #0:4(deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s (visual impaired) (descriptions) Stream #0:5(deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, fltp, 448 kb/s Stream #0:6(mul): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 192 kb/s (hearing impaired) Stream #0:1(deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006), 492x250 Stream #0:7(deu): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) (hearing impaired) Stream #0:8: Unknown: none ([5][0][0][0] / 0x0005) Program 11160 Metadata: service_name : KiKA HD service_provider: ZDFvision Program 11170 Metadata: service_name : ZDFinfo HD service_provider: ZDFvision No Program Stream #0:2: Data: epg Unsupported codec with id 98306 for input stream 2 Unsupported codec with id 0 for input stream 8 So - my question: are there some ports automatically blocked on TrueNas Scale running official emby container ? Do i have to enabel port 554 anywhere ? ICMP and http/https seems open at default... @ErikaJ: i am using a Sat>IP converter in my local LAN with a local dish - so the are nor area limitations for me which i would solve with a vpn. thx for feedback anyways.
Luke 42242 Posted March 23, 2023 Posted March 23, 2023 Is rtsp still your only option? It doesn't support http output?
