guill69f 17 Posted December 8, 2022 Posted December 8, 2022 Hi, I need some help with subtitles download. It seems I have configured OpenSubtitles correctly as i can manually download subtitles one movie at a time, but the scheduled task "Download subtitles" does not seem to provide any results, and i cannot figure out why. What i'd like it to do, so to check if i already have subtitles in one of the three languages I have specified, and if I don't, to search and download subs for these languages from OpenSubtitles. See in the picture how i have set-up the parameters. I am not sure of where to check to see if anything is not working, or if any subtitles have been successfully downloaded. When i look into the log, which i am not sure on how to read, and search for "download", i find this line: 2022-12-08 06:29:07.183 Error SubtitleManager: Error downloading subtitles from Open Subtitles Probably that explains, but what does it mean and how can i solve this? Thanks!
Solution rodainas 191 Posted December 8, 2022 Solution Posted December 8, 2022 Uncheck Require hash match
Luke 42186 Posted December 8, 2022 Posted December 8, 2022 Hi, yes, did you make sure to read the help text underneath that option?
guill69f 17 Posted December 8, 2022 Author Posted December 8, 2022 Oh my god, rookie mistake, can't believe it!!! Would have been less embarrassing to say that I didn't read it, but i actually did, understood it, and then, well, forgot it I have now unchecked the box and did some checks and things seems to work like a charm Thanks again 1
