levelhead1us 1 Posted December 8, 2022 Posted December 8, 2022 Is there any way to send emby controls through the command line interface (cli)? I'm specifically looking to control things like: - refreshing guide data for the TV (ie - as soon as I put a new m3u file out there, I want to be sure that emby refreshes) - forcing a rescan of the library files (for whatever reason it sometimes does not run when I want it to & I want to force it) I basically want to script some things so that they are sure to happen immediately. For whatever reason, emby doesn't recognize that some things have changed when they have.
Happy2Play 9812 Posted December 8, 2022 Posted December 8, 2022 @levelhead1us Just api curl calls. example topic but there are others out there. Might have a CORS issue but there is a link at the bottom of the Dashboard. Could possibly get what you need by looking at a debug server log after running the specific task. Just need to create your own api key via Settings-API Keys
Luke 42245 Posted December 8, 2022 Posted December 8, 2022 Hi, have you taken a look at this? https://github.com/MediaBrowser/Emby/wiki
