sngreco 1 Posted October 16, 2023 Posted October 16, 2023 5 hours ago, nabla79 said: I have run a test on my Echo Show 15 by using the Live App Testing flow. I confirm that your last beta version works correctly. I will wait for the new official release. Do you have a link to documentation I could use to test this method as well? I couldn't find anything before.
nabla79 4 Posted October 17, 2023 Posted October 17, 2023 10 hours ago, sngreco said: Do you have a link to documentation I could use to test this method as well? I couldn't find anything before. https://developer.amazon.com/docs/app-testing/live-app-testing-getting-started.html
Trunks.san 3 Posted November 10, 2023 Posted November 10, 2023 too bad the PLEX apps is on echo show 15 and EMBY not...
ebr 16337 Posted November 11, 2023 Posted November 11, 2023 Hi. Ours is in the process of being released.
Trunks.san 3 Posted November 18, 2023 Posted November 18, 2023 Emby is available on the appstore on echo show 15 and works very well. thanks 1 2
MagicDoubleM 121 Posted December 2, 2023 Author Posted December 2, 2023 Had it working a few days ago, but currently it's broken for me. When i try to start the client, it jumps to the store-page and gives me the option to download/install, but the install fails. I'm in the beta-program, so maybe that's the problem?
Luke 42244 Posted December 2, 2023 Posted December 2, 2023 5 minutes ago, MagicDoubleM said: Had it working a few days ago, but currently it's broken for me. When i try to start the client, it jumps to the store-page and gives me the option to download/install, but the install fails. I'm in the beta-program, so maybe that's the problem? Hi there, what exactly happens when you try to install?
MagicDoubleM 121 Posted December 2, 2023 Author Posted December 2, 2023 34 minutes ago, Luke said: Hi there, what exactly happens when you try to install? There are no real infos, unfortunately. It worked a few days ago...
Luke 42244 Posted December 2, 2023 Posted December 2, 2023 29 minutes ago, MagicDoubleM said: There are no real infos, unfortunately. It worked a few days ago... Are you able to install this: https://www.amazon.com/Emby-for-Android/dp/B00GVH9O0I
MagicDoubleM 121 Posted December 2, 2023 Author Posted December 2, 2023 2 minutes ago, Luke said: Are you able to install this: https://www.amazon.com/Emby-for-Android/dp/B00GVH9O0I No, the .com links i blocked due to geographical restrictions, and the .de-version of this link only offers me to install this to my FireTablet, but not to a EchoSow15. It also doesn't show up when I search for it on the device itself. However, I just noticed that when I search for emby I get a link (icon without beta-mark) in the results which starts the version I installed last week (.98). On the launcher however I get an icon with the beta-mark, which leads me to the store-link and, well, see above... I also noticed that I have two Icons on my FireTVCube, one with the beta-mark and one without, both start the same version (my sideloaded .99).
ebr 16337 Posted December 3, 2023 Posted December 3, 2023 Hi. Amazon removed all of our beta testers for this app a while ago so I'm not sure why you would still be seeing a beta link. Is there something in your Amazon account that would allow you to "leave" the beta?
