Przemek 70 Posted December 7, 2022 Posted December 7, 2022 Hello, I noticed that after last upgrade of Emby Server (4.7.10.0) I cannot make epg link work. It refresh very fast and there's no guide. I try all links from that website: https://epg.ovh/ It works great until last upgrade. I can only add file that I download from that website but it will stop working after few days. Regards. embyserver.txt
Luke 42237 Posted December 7, 2022 Posted December 7, 2022 Hi there, why do you think it stops working?
Przemek 70 Posted December 7, 2022 Author Posted December 7, 2022 14 minutes ago, Luke said: Hi there, why do you think it stops working? Because there's no guide if I add link.
Solution Luke 42237 Posted December 7, 2022 Solution Posted December 7, 2022 Maybe the problem is actually your m3u tuner? 2022-12-07 12:38:27.605 Error M3UTunerHost: Error getting channel list *** Error Report *** Version: 4.7.10.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.10.0-19-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.DirectoryNotFoundException: System.IO.DirectoryNotFoundException: Could not find a part of the path '/mnt/Toshiba/dietpi_userdata/IPTV/Sports-IPTV-List-1-13-09-2022.m3u'. 1
Przemek 70 Posted December 7, 2022 Author Posted December 7, 2022 (edited) On 10/22/2022 at 11:49 PM, GWTPqZp6b said: Hi, I'm very sorry I didn't notice that in log. I recently change HDD and now path is different. Regards. Edited December 11, 2022 by Przemek 1
Przemek 70 Posted December 11, 2022 Author Posted December 11, 2022 Hi @Luke, today I have the same problem. Cannot add guide with link, but can add with file. There's some https error in log. My iptv works great. I have correct path to m3u file. embyserver.txt
Luke 42237 Posted December 11, 2022 Posted December 11, 2022 Yea looks like some problem with the website hosting the xml.
Przemek 70 Posted January 9, 2023 Author Posted January 9, 2023 On 12/11/2022 at 9:48 PM, Luke said: Yea looks like some problem with the website hosting the xml. I find some github page with polish epg and so far works OK. Thanks. 1
outlaw69uk 7 Posted January 15, 2023 Posted January 15, 2023 Mine works fine on pc, but not on the android tv or iPhone apps. Iptv works but there just is no guide data. Do you have to manually set it to refresh on the server or something?
Przemek 70 Posted January 15, 2023 Author Posted January 15, 2023 41 minutes ago, outlaw69uk said: Mine works fine on pc, but not on the android tv or iPhone apps. Iptv works but there just is no guide data. Do you have to manually set it to refresh on the server or something? Hi, I have shedule job for refreshing guide in Emby. Some EPG sources cause troubles because program names don't match. Regards.
Luke 42237 Posted January 16, 2023 Posted January 16, 2023 On 1/15/2023 at 9:30 AM, outlaw69uk said: Mine works fine on pc, but not on the android tv or iPhone apps. Iptv works but there just is no guide data. Do you have to manually set it to refresh on the server or something? Hi there, why do you think it doesn't work?
outlaw69uk 7 Posted January 16, 2023 Posted January 16, 2023 9 minutes ago, Luke said: Hi there, why do you think it doesn't work? If I knew, I wouldnt have asked the question I dont code, or anything like that, and, I dont have this issue on any other platform
Luke 42237 Posted January 16, 2023 Posted January 16, 2023 6 hours ago, outlaw69uk said: If I knew, I wouldnt have asked the question I dont code, or anything like that, and, I dont have this issue on any other platform Did you try restarting the app after refreshing the guide in the server?
tierzero 0 Posted May 12, 2023 Posted May 12, 2023 I know that this is an older post at this point, but for what it's worth I just finished going through exactly this issue and was getting quite frustrated with it. I also apologize if this has already been answered elsewhere... I just wasn't able to find it and wanted to share the knowledge. A response from another post lead me down the path that made everything make sense... No amount of EPG guide messing/configuring was getting ANY of the channels to show up in the guide, even though I could see them all and play them fine through Tags, Channels, etc. This all started happening to me after I was forced to do an update/reinstall (keeping settings) after a system issue. It turns out that during the reinstall my guide settings dropped all "Channel Tags". Once I re-selected my channel tags everything started working again. I spent hours and hours spread across many days trying to figure this out, but it was that simple. So, if anyone is having an issue where after an update their guide just disappears, then I'd start by checking here and not by deleting your EPG source or playing around with other EPG providers. There's a good chance this setting just didn't carry over properly.
Luke 42237 Posted May 13, 2023 Posted May 13, 2023 6 hours ago, tierzero said: I know that this is an older post at this point, but for what it's worth I just finished going through exactly this issue and was getting quite frustrated with it. I also apologize if this has already been answered elsewhere... I just wasn't able to find it and wanted to share the knowledge. A response from another post lead me down the path that made everything make sense... No amount of EPG guide messing/configuring was getting ANY of the channels to show up in the guide, even though I could see them all and play them fine through Tags, Channels, etc. This all started happening to me after I was forced to do an update/reinstall (keeping settings) after a system issue. It turns out that during the reinstall my guide settings dropped all "Channel Tags". Once I re-selected my channel tags everything started working again. I spent hours and hours spread across many days trying to figure this out, but it was that simple. So, if anyone is having an issue where after an update their guide just disappears, then I'd start by checking here and not by deleting your EPG source or playing around with other EPG providers. There's a good chance this setting just didn't carry over properly. Hi, we’ll take a look at this. Thanks .
