ab123ga 18 Posted October 12, 2014 Posted October 12, 2014 For the past few days, I've been having an issue /w MB connecting to serverwmc. I have the app start every morning but lately when I attempt to connect to LiveTV (recordings, channels etc) I get nothing without having to either kill and restart serverwmc or restart MB. Today I had the issue and ran a test with XBMC access and it seemed to have no issue getting the guide, recordings etc. MB...no go. Finally I rebooted MB and then the access was there. Timeline. The last time I checked before rebooting was around 9:53E. I rebooted MB about 30 min later and all works now. MB and serverwmc logs loaded. https://app.box.com/s/0e1y9uphcz3ryfjk2ymf
Luke 42237 Posted October 12, 2014 Posted October 12, 2014 probably you started MBS before server wmc. it runs the refresh guide task at startup. if you're starting swmc after MBS then you should either run the task manually or adjust the schedule for it
ab123ga 18 Posted October 12, 2014 Author Posted October 12, 2014 Good point. I do reboot all of my systems in the early hours of the morning. I'll adjust to where MB system reboots after.
krustyreturns 191 Posted October 12, 2014 Posted October 12, 2014 I just released a new version of the serverwmc plugin (1.0.0.43) that should fix this problem. It should allow MBS to start before swmc. Thanks @@Luke.
ab123ga 18 Posted October 12, 2014 Author Posted October 12, 2014 Krusty... do you want me to test? I've already switched which loads 1st but can put it back to the way it was.
ab123ga 18 Posted October 12, 2014 Author Posted October 12, 2014 System says I'm up to date. Once the update is available, I'll try it.
Karen 0 Posted October 14, 2014 Posted October 14, 2014 Hi guys. I was just wondering if this plugin was tested. I've got some start up coordination questions as well. I've tried to start the Mediabrowser server as a Windows 7 service and then set the ServerWMC to start when Windows starts. But that never seemed to work properly. When I go in and attempt to use LiveTV it just says "no connection" when I look in the channels section. Is this a valid start up method, or can someone suggest a better way? I'd just like to have things start auto-magically when I turn on Win7.
krustyreturns 191 Posted October 14, 2014 Posted October 14, 2014 Can you verify which version of the plugin you are using?
Karen 0 Posted October 14, 2014 Posted October 14, 2014 (edited) Hi krustyreturns, I will double check the version as soon as I get home and post a reply. Edited October 14, 2014 by Karen
Karen 0 Posted October 14, 2014 Posted October 14, 2014 Hi krustyreturns, I will double check the version as soon as I get home and post a reply. I've taken a look at my code versions, and here they are: Mediabrowser Server 3.0.5395.0 Mediabrowser ServerWMC plugin 1.0.0.43 ServerWMC 1.0.0.42 build 1167 The good news is that everything works as advertised, leaving me a bit mystified why it didn't appear to work before. Oh well, when I set Mediabrowser to start as a service, or a delayed start service, it works just fine. Krustyreturns, your plugin works fine. Thank you for your patience. Time for a bit of TV
bloodtaker 71 Posted October 19, 2014 Posted October 19, 2014 A Live TV service provider plugin is required in order to continue. Please install one of our available plugins, such as Next Pvr or ServerWmc. I have verified I have yet it will not register inside of media browser that it has the plugin installed. It worked previously like a charm as this is the first time i have had this issue arise. 1.0.0.43 ServerWMC plugin Version 3.0.5404.29588 MBS dev build ServerWMC 1.0.0.42 build 1167
krustyreturns 191 Posted October 19, 2014 Posted October 19, 2014 This is due to am MBS dev update and my plugin is not up with the new changes. Working on it now. 1
bloodtaker 71 Posted October 19, 2014 Posted October 19, 2014 10 - 4 Thought it was something along those lines. Great work on it by the way
krustyreturns 191 Posted October 20, 2014 Posted October 20, 2014 I just put up a new dev version of the plugin that solves this problem.
