sbordun 0 Posted December 6, 2022 Posted December 6, 2022 (edited) HI, I have Q60A TV (Tizen) and having issues to play videos with 60fps (1080 or 4k). videos with 30p play correctly, but when trying to play 60p videos - I see error on TV. Is it Emby server or client bug/configuration issue ? or it is TV is not compatible to play 60p files? Thanks Edited December 6, 2022 by sbordun
Luke 42240 Posted December 6, 2022 Posted December 6, 2022 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
sbordun 0 Posted December 7, 2022 Author Posted December 7, 2022 (edited) Hi @Luke, I attached log files. each folder contains readme.txt file was the exact time when mp4 was played. I restarted Emby server before each test. 1)4k60p and 1080x60p were not played at all , it was just error message on TV: "Playback Error, No compatible streams are currently available......." 2)4k30p and 1080x30p were played successfully. I did all tests on: "32” Class Q60A QLED 4K Smart TV (2021)" TV with 60Hz refresh rate I am using "Emby for Samsung 1.2.6" app that was installed from Samsung store directly on TV (US localization). Thanks! logs.zip Edited December 7, 2022 by sbordun
SamES 1084 Posted December 7, 2022 Posted December 7, 2022 The 4k60p file is h264. I think on your model, only 30fps is supported for that format in 4K. That's a special case we would have to add for some models, but all it will do is transcode it to 30fps, which may not be much use to you I'm not sure about the 1080x60p. Can you please try turning off Hardware Acceleration in the transcoding settings and see if that resolves the issues?
sbordun 0 Posted December 7, 2022 Author Posted December 7, 2022 (edited) Hi @SamES, I tried your suggestion by turning off Hardware acceleration in transcoding settings. It didn't help. Both 1080@60p and 4k@60p were not played on TV. it is strange that 1080@60p is not playing! here is the manual for my TV (QN32Q60AAFXZChttps://downloadcenter.samsung.com/content/UM/202209/20220930095221952/OSNATSCA-8.4.0_EM_Oscar_Nike_Kant-SU2e_USA_ENG_220825.0.pdf Please look into page# 145. (screen shot of page 145 was attached). If I understand the table from the page 145, my Tv supposed to play 60p in 1080 resolution. I am open for other advices how to troubleshoot 1080@60p playback issue. Thank You! Edited December 7, 2022 by sbordun
SamES 1084 Posted December 7, 2022 Posted December 7, 2022 4 hours ago, sbordun said: I tried your suggestion by turning off Hardware acceleration in transcoding settings. It didn't help. Both 1080@60p and 4k@60p were not played on TV. it is strange that 1080@60p is not playing! Thanks for testing, that's not unexpected, but was worth confirming. While I agree with your comments regarding the 1080p playback, there are a lot of possible encoding options, and the Samsung internal player does not support them all. In this case, it will still fail. For example, these are some of the options that Samsung call out as being not supported, but there are many more. It's very hard to know which is really the issue When files are encododed, fairly 'standard' settings need to be selected. The fact that Transcoding also fails suggests there is a problem with the encoding of this file. If you put it on a USB drive and connect it directly to the TV, does it play using the TV's internal player?
sbordun 0 Posted December 7, 2022 Author Posted December 7, 2022 @SamES, I copied all files to USB flash and were able to play successfully 1080@60p (h.264) file only. 4k@60p (h.264) was not played, instead I have seen the error message: ".....the format is not supported...." . I have done an additional test by creating a new file 4k@60p HEVC(h.265) and it was played successfully from both: USB flash and Emby app on TV. As expected according to specs I have attached earlier. Could you troubleshoot the issue with me: Why 1080@60p (h.264) file is not playing in Emby TV app, but working from USB flash ? Thanks
SamES 1084 Posted December 8, 2022 Posted December 8, 2022 12 hours ago, sbordun said: Why 1080@60p (h.264) file is not playing in Emby TV app, but working from USB flash ? I'm assuming you've had multiple attempts at playing this in Emby and they all fail? To be honest, it's going to be a hard one to troubleshoot. I can see from the log that the player tried to DirectPlay the file, but it failed, so it then tried to convert it for playback. When this happens, we don't get any meaningful errors from the player and there aren't really any settings that we adjust to try and make it play. If you want, you can PM a link to me where I can download this file from you to test. I might not be able to reproduce it if it plays fine on my TV, but happy to give it a go
SamES 1084 Posted December 8, 2022 Posted December 8, 2022 You can test this 1080p/60fps sample, it plays fine for me. I'm curious to see if it works fine for you http://distribution.bbb3d.renderfarming.net/video/mp4/bbb_sunflower_1080p_60fps_normal.mp4
sbordun 0 Posted December 8, 2022 Author Posted December 8, 2022 the same issue for your file "bbb_sunflower_1080p_60fps_normal.mp4": not playing in Emby TV app, but playing from USB flash. do you still need my sample file?
SamES 1084 Posted December 8, 2022 Posted December 8, 2022 Probably not. I'll check to documentation again, but it's possible that Samsung player available to the app isn't as compatible as the TV's internal player. We have seen that before in some cases.
sbordun 0 Posted December 10, 2022 Author Posted December 10, 2022 Is it related to Emby Tv App version? I am using outdated "Emby for Samsung 1.2.6", Only this version is available in Samsung store for US region.
SamES 1084 Posted December 10, 2022 Posted December 10, 2022 I doubt it, but you can try the USB version.
