BloodyPiker 1 Posted December 6, 2022 Posted December 6, 2022 I recently updated to 4.7.10.0 and started having issues with live TV. I and found that when the channel guide is configured I get an error in the log. 2022-12-05 21:48:05.567 Info LiveTV: Discovered tuner device HD Homerun at http://192.168.1.98 2022-12-05 21:48:05.568 Info LiveTV: Discovered tuner device HD Homerun at http://192.168.1.98 2022-12-05 21:48:05.568 Info HttpClient: GET http://192.168.1.98/discover.json 2022-12-05 21:48:05.570 Info HttpClient: GET http://192.168.1.98/lineup.json 2022-12-05 21:48:05.588 Error LiveTvManager: Error refreshing channels for service *** Error Report *** Version: 4.7.10.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.15.0-56-generic (buildd@lcy02-amd64-004) (gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #62-Ubuntu Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'source') at System.Linq.ThrowHelper.ThrowArgumentNullException(ExceptionArgument argument) at System.Linq.Enumerable.Select[TSource,TResult](IEnumerable`1 source, Func`2 selector) at EmbyGuideData.Gracenote.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetEpgChannelData(IListingsProvider provider, ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.QueryChannelsAsync(ChannelManagementQuery query, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelsAsync(CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshEmbyChannelsInternal(IProgress`1 progress, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) Source: System.Linq TargetSite: Void ThrowArgumentNullException(System.Linq.ExceptionArgument) When I don't have the Emby Guide configured, the channels load just fine. Unsure how to correct. I have tried installing older versions of the guide, but seams to revert to the latest after a restart. embyserver.txt
Solution Luke 42237 Posted December 6, 2022 Solution Posted December 6, 2022 Hi, I just pushed an update to the emby guide data plugin. Please let me know if that helps. Thanks.
BloodyPiker 1 Posted December 6, 2022 Author Posted December 6, 2022 Thanks, Luke! I can now configure the guide source and it doesn't error out. However, it is unable to match to the channels and I am unable to manually bind them. 2022-12-06 17:00:44.066 Info LiveTvManager: Refreshing guide with 7 days of guide data 2022-12-06 17:00:44.073 Debug LiveTV: Getting programs for channel 3.1-KMTV-TV from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.073 Debug LiveTV: EPG channel not found for tuner channel 3.1-KMTV-TV from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.073 Debug LiveTvManager: Channel KMTV-TV has 0 programs 2022-12-06 17:00:44.073 Debug LiveTV: Getting programs for channel 3.2-Grit from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.073 Debug LiveTV: EPG channel not found for tuner channel 3.2-Grit from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.074 Debug LiveTvManager: Channel Grit has 0 programs 2022-12-06 17:00:44.074 Debug LiveTV: Getting programs for channel 3.3-LAFF-TV from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.074 Debug LiveTV: EPG channel not found for tuner channel 3.3-LAFF-TV from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.074 Debug LiveTvManager: Channel LAFF-TV has 0 programs 2022-12-06 17:00:44.074 Debug LiveTV: Getting programs for channel 3.4-Escape from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.074 Debug LiveTV: EPG channel not found for tuner channel 3.4-Escape from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.075 Debug LiveTvManager: Channel Escape has 0 programs 2022-12-06 17:00:44.075 Debug LiveTV: Getting programs for channel 3.5-CourtTV from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.075 Debug LiveTV: EPG channel not found for tuner channel 3.5-CourtTV from Emby Guide Data-USA-OTA68007 2022-12-06 17:00:44.075 Debug LiveTvManager: Channel CourtTV has 0 programs in the channel manager, the channels report that they are not mapped to guide data. When selecting the channel and configuring the guide source to Emby Guide, the guide channel data does not allow selection or input. embyserver (1).txt
BloodyPiker 1 Posted December 7, 2022 Author Posted December 7, 2022 Disregard. I just rechecked and the guide is now working and channels are mapped. Thanks again for the help. 1
