MattDrayton 1 Posted December 3, 2022 Posted December 3, 2022 Buenos días, me compre un android tv MECOOL KM2 Plus y instale emby y me dado cuenta que no reproduce el sonido DTS 5.1 y DTS-HD MA 5.1 que debería decodificar por defecto. Alguna solución? Gracias
Luke 42239 Posted December 5, 2022 Posted December 5, 2022 @MattDrayton Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
MattDrayton 1 Posted December 5, 2022 Author Posted December 5, 2022 Donde esta la carpeta de transcodificación para sacar el regitro, tengo el campo en blanco
MattDrayton 1 Posted December 5, 2022 Author Posted December 5, 2022 Y aquí tienes el registro del servidor embyserver.txt
MattDrayton 1 Posted December 14, 2022 Author Posted December 14, 2022 (edited) Alguna solución, es que estoy harto de EMBY TIZEN OS Edited December 14, 2022 by MattDrayton
Luke 42239 Posted December 14, 2022 Posted December 14, 2022 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
MattDrayton 1 Posted December 15, 2022 Author Posted December 15, 2022 Me pone que este dispositivo no es compatible con el dispositivo, el MECOOL KM2 Plus es un ANDROID TV Alguna solución más? Gracias
Luke 42239 Posted December 15, 2022 Posted December 15, 2022 2 hours ago, MattDrayton said: Me pone que este dispositivo no es compatible con el dispositivo, el MECOOL KM2 Plus es un ANDROID TV Alguna solución más? Gracias Hi, did you try sideloading the apk?
Luke 42239 Posted January 4, 2023 Posted January 4, 2023 @MattDrayton Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
MattDrayton 1 Posted March 12, 2023 Author Posted March 12, 2023 Lo he probado con la apk y no reproduce el audio no reproducen el DTS 5.1 y DTS-HD MA 5.1, en cambio he instalado plex y si reproduce el sonido, que esta pasado?? Gracias
Luke 42239 Posted April 17, 2023 Posted April 17, 2023 On 3/12/2023 at 2:27 PM, MattDrayton said: Lo he probado con la apk y no reproduce el audio no reproducen el DTS 5.1 y DTS-HD MA 5.1, en cambio he instalado plex y si reproduce el sonido, que esta pasado?? Gracias @MattDrayton what version of android does this device run?
MattDrayton 1 Posted April 17, 2023 Author Posted April 17, 2023 Versión de SO de Android TV 11. alguna info mas que quieras saber del sistema
Luke 42239 Posted April 18, 2023 Posted April 18, 2023 On 4/13/2023 at 2:14 AM, Yarraspb said: Mi Pad - Android 12 SP1 (MIUI 13) S23 - Android 13 (One UI 5.1) @MattDrayton Can you please try sideloading this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 Then start the app, reproduce the problem, and then provide an android app log by following these instructions here: Thanks !
MattDrayton 1 Posted May 21, 2023 Author Posted May 21, 2023 No he podido acceder a la carpeta data con ningún administrador de archivo. QUE HAGO??
Luke 42239 Posted June 14, 2023 Posted June 14, 2023 On 5/21/2023 at 1:27 PM, MattDrayton said: No he podido acceder a la carpeta data con ningún administrador de archivo. QUE HAGO?? Hi, have you tried CX File Explorer?
MattDrayton 1 Posted June 15, 2023 Author Posted June 15, 2023 No puedo acceder a la carpeta data, me sale esto Que hago??
Luke 42239 Posted July 2, 2023 Posted July 2, 2023 @clarkss12do you know how to do this on the MeCool?
