justpushplay 6 Posted November 26, 2022 Posted November 26, 2022 Hi All, I just now noticed that I had no guide data past this afternoon, (11.26.22) so I went in to refresh it, and now I don't have any guide data at all. I have deleted and restarted the Emby guide source and the HDHomerun Quatro tuner, but no change, no guide data. It briefly shows a bit of green bar, then stops. I am pulling down OTA data for the 65737 zip code. Reboots, etc. have no effect. I've included the log file from immediately after attempting to load the guide data. I am currently on Starlink for internet, but it is no different when I go to my AT&T LTE backup. Also, no change whether I'n on PIA VPN or not. Has anyone else experienced this since the 4.7.10 update? embyserver.txt
justpushplay 6 Posted November 27, 2022 Author Posted November 27, 2022 Aha! Apparently the guide issue has resolved itself.
Luke 42239 Posted November 28, 2022 Posted November 28, 2022 HI, thanks for following up. I'm not quite sure what happened but in the log it looks like bad or empty data may have been coming from our guide data provider for a short period of time.
justpushplay 6 Posted November 28, 2022 Author Posted November 28, 2022 Glad it was a temporary thing. I was afraid something broke in the update. Thanks for checking in! 1
justpushplay 6 Posted December 2, 2022 Author Posted December 2, 2022 Mods, let me know if I should start a new thread for this. Hi again, The guide issue just resurfaced, when I realized that some shows didn't record this week. Here's the log, and let me know if you need anything else to help out. embyserver.txt
justpushplay 6 Posted December 2, 2022 Author Posted December 2, 2022 Oops. This may be the correct lg file. embyserver.txt
justpushplay 6 Posted December 3, 2022 Author Posted December 3, 2022 I posted this earlier in a previous thread, but it has reappeared after solving itself. I noticed some scheduled recordings did not record this week, and noticed that I was missing guide data. I attempted to refresh the guide date, which started to download, with just a bit of the green progress bar, then quit. Guide data did not get updated, so I'm wondering if this is isolated to me, or if it occurs for anyone else here. Luke said the logs showed that there may have been some missing data from their guide data provider. Is it just my zip code? (65737) Log is attached below. embyserver.txt
Luke 42239 Posted December 5, 2022 Posted December 5, 2022 Hi @justpushplay this latest log file looks OK to me. What channel exactly is missing guide data?
justpushplay 6 Posted December 5, 2022 Author Posted December 5, 2022 Hi Luke, It's not any one specific channel, the guide gets truncated across all channels. Again, I'm pulling data for OTA in the 65737 zip. In this specific case, it is now 11:20PM, and the guide was only populated to 4AM. I just refreshed the guide, and it only updated to 9AM. The preferences are set to the maximum 14 day refresh. I included another log taken after the refresh. Is there something else that I could try to help? Michael embyserver.txt
Luke 42239 Posted December 5, 2022 Posted December 5, 2022 Why exactly do you think it only updated to 9am?
iiiJoe 62 Posted December 5, 2022 Posted December 5, 2022 I know this is a dumb question but have you double checked to make sure your guide is being populated by THE Emby guide data? Also, have you restarted your server and any client devices and cleared your cache?
justpushplay 6 Posted December 5, 2022 Author Posted December 5, 2022 I can tell it isn't updating by looking at the guide. All the channels in the guide are blank after that hour. The server has been rebooted, safari browser cache etc. cleared, Emby server cache cleared, and MacMini rebooted. Emby guide data deleted, and started from scratch. Not sure what to try next. Log and screenshot attached. embyserver.txt
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 Ok. Click on the channel logo then click on the three dots and choose edit metadata and it’ll show you what source it’s using for guide data. Just make sure it’s the Emby guide data and on the correct corresponding channel. I attached a few pics because I always feel like it’s easier if someone (me, lol) can see it.
justpushplay 6 Posted December 6, 2022 Author Posted December 6, 2022 It appears to indeed be the Emby guide data. And yes, you're instructions were awesome:-)
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 Ty sir! Sooo, just for kicks what if you changed from Emby guide data OTA to a Emby guide data direct tv?
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 Man, that is really weird. Just trying to think outside of the box here, is it possible that the destination folder that holds the guide data is mostly full and can only hold a few hrs of new data?
justpushplay 6 Posted December 6, 2022 Author Posted December 6, 2022 (edited) Oh wait. That's going all the way out to Jan. 21st? EDIT: Where is the destination folder? Looking through stuff I've found station logos and such. Edited December 6, 2022 by justpushplay
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 Now its getting REALLY weird, lol! I think it’s only supposed to go out like 14 days max
justpushplay 6 Posted December 6, 2022 Author Posted December 6, 2022 (edited) And this is a 3 week old clean install of MacOS Monterey. The only thing this Mac does is sit in the rack and run Emby and Apple Music. No email, no surfing other than Emby and occasionally radar when it storms. EDIT: Tomorrow I'll go in and delete all the Emby stuff including the hidden library and start all over. All of the media resides on an external drive so it's not much to start fresh. Edited December 6, 2022 by justpushplay
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 I call that a cosmic mystery. I’ve had a number of them recently. But the directv guide data worked?
justpushplay 6 Posted December 6, 2022 Author Posted December 6, 2022 Yes, it worked, for at least the local channels that DTV carries. Wait, shouldn't it have populated with ALL of the stuff DTV carries.
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 Great! Only the channels for which you manually change the guide data source will update. Each individual channel has to be pointed to the desired source and corresponding channel #. Kind of a pain at first, but once you get it set up it’s rock solid.
justpushplay 6 Posted December 6, 2022 Author Posted December 6, 2022 just tried loading Dish Network USA, and it only loaded the same 4 locals, which in fact are not all of the locals. Flummoxed, I am!!
iiiJoe 62 Posted December 6, 2022 Posted December 6, 2022 Strange indeed. So it’s possible that the guide data for your area is incomplete. Which channels you looking for? I can check on my server, just need a zip too please
