Machete 5 Posted December 2, 2022 Posted December 2, 2022 (edited) Bonjour, Suite a un reset usine de mon nas terramaster; j'ai reinstallé Emby. Celui ci fonctionne a merveille sur le reseau local, mais la connexion est systematiquement refusé lors de la connexion a distance. Je vous joint les logs. Auriez vous une idée sur ce probleme ? Merci ------------------------ Hello, Following a factory reset of my nas terramaster; I reinstalled Emby. This one works perfectly on the local network, but the connection is systematically refused during the remote connection. I attach the logs. Do you have any idea about this problem? Thanks embyserver.txt embyserver-63805543234.txt hardware_detection-63805600999.txt Edited December 2, 2022 by Machete
Luke 42237 Posted December 14, 2022 Posted December 14, 2022 Hi @Machete are you still having an issue with this?
Machete 5 Posted December 14, 2022 Author Posted December 14, 2022 Bonjour, Je rencontre malheuremsent toujours le souci... ----- Hello, Unfortunately, I still encounter the problem... -
Machete 5 Posted January 10, 2023 Author Posted January 10, 2023 Oui j'ai bien la derniere mise a jour 4.7.11. Je crois que le souci viens de mon NAS. Le wake on lan ne fonctionne plus dessus, et je n'arrive pas non plus a y acceder a distance...Je vais ouvrir un ticket chez TERRAMASTER.
Machete 5 Posted January 11, 2023 Author Posted January 11, 2023 Apres avoir contacté le support de terramaster le souci ne semble pas venir de mon nas, celui ci est bien accessible a distance. Cordialement
rbjtech 5341 Posted January 13, 2023 Posted January 13, 2023 Have you setup remote access to forward the external access/ports to your emby server on 192.168.1.20 ? Try following the guide here and report back - https://support.emby.media/support/solutions/articles/44002137137-remote-setup
Machete 5 Posted January 13, 2023 Author Posted January 13, 2023 Bonjour; J'ai réglé le probleme. Celui ci viens du fait que ma box soit configurer en IPV6. Du coup dans Emby l'addresse d'acces a distance ne fonctionne pas. Sur ma box apparait l'ipv4 qui elle fonctionne parfaitement a distance... Je suis désolé pour le temps que je vous ai fait perdre. Merci de votre aide.
Machete 5 Posted January 13, 2023 Author Posted January 13, 2023 Alors j'ai été un peu vite en besogne...cela ne fonctionne pas non plus. J'ai 3 ip differentes pour acceder a ma box. La local, l'ipv4 & l'ipv6. Mais aucune d'elle ne fonctionne sur un reseau 4G. J'ai bien fait le redirection de port mais cela ne change rien..
Solution Machete 5 Posted January 20, 2023 Author Solution Posted January 20, 2023 Mon souci est réglé depuis que je suis repassé en IPV4. C'etait bien l'IPV6 qui posait probleme... Merci pour votre aide ! 1
