Mikemodi 0 Posted December 2, 2022 Posted December 2, 2022 Hi I completed my dashboard page and also created one gujarati movies folder, after that nothing gets updated. Also under live tv option I don't see any viewing options. Is there way you can help me set up further by accessing my dashboard, thank you in advance.
pwhodges 2024 Posted December 2, 2022 Posted December 2, 2022 I think we need to know a bit more about what you've done to offer any useful advice; see here: You say "nothing gets updated" - but what updates are you waiting for? Is the initial content of the library you've set up visible? Copying the server log file here would be helpful. As regards live TV, have you set up a TV source, and have you purchased Premiere to enable it? Paul
Mikemodi 0 Posted December 2, 2022 Author Posted December 2, 2022 As regards to live tv, how do I get automatic m3u urls? No I haven’t purchased premier to enable it. Also I installed all the media links folders like iptv, trakt etc..but then nothing happens. under the library so far I created Gujarati movies folder but there is no files that I received from any sources.
pwhodges 2024 Posted December 2, 2022 Posted December 2, 2022 Emby won't display any files until you put them in the library folder. When you do, so long as you follow the naming and folder structure conventions, Emby will then fetch metadata and images for each one. Note that Emby themselves do not provide content - it is up to you to find it. Live TV will not work without a Premiere subscription. Again, Emby does not provide feeds - you tell Emby what feeds you have available. Paul
Luke 42186 Posted December 2, 2022 Posted December 2, 2022 Quote under the library so far I created Gujarati movies folder but there is no files that I received from any sources. What folders did you add to the library? Do you have any files in those folders?
Mikemodi 0 Posted December 6, 2022 Author Posted December 6, 2022 No files. How to get files for that folder
pwhodges 2024 Posted December 6, 2022 Posted December 6, 2022 That's up to you. You put your files into the folders for Emby to stream for you - Emby does not supply files. Paul
