MrPancake 10 Posted November 30, 2022 Posted November 30, 2022 (edited) Hello, I have a series that takes about 30 seconds after I click play, to start playing on my Samsung Tizen TV (2015). The "loading" circle keeps spinning during the process. Looking at the logs, I couldn't find anything suspicious, apart from lines like this after I click play: Quote 2022-11-30 20:50:22.965 Info Server: http/1.1 Response 206 to host4. Time: 26399ms. I tested playing the same files on Emby Theatre in windows and on an android phone and it starts almost instantly, so no problems there. It says audio and video are direct playing, but have this on the top: Stream MKV (5 mbps) ->HLS (5 mbps) Converting to compatible container I'm running Emby Server 4.7.10.0 on a Synology DS920+ NAS. No problems with the rest of my media collection. Thank you! embyserver.txt ffmpeg-directstream-ca9a819c-fff8-4ee4-b359-3bf12f084521_1.txt Edited November 30, 2022 by MrPancake
MrPancake 10 Posted December 1, 2022 Author Posted December 1, 2022 2 hours ago, Luke said: Hi, what model Samsung? Hi, its a ue65js9000
MrPancake 10 Posted December 6, 2022 Author Posted December 6, 2022 Hi @Luke, any progress with this? Thanks
Luke 42186 Posted December 26, 2022 Posted December 26, 2022 Hi @MrPancakeare you still having an issue with this?
MrPancake 10 Posted December 26, 2022 Author Posted December 26, 2022 3 minutes ago, Luke said: Hi @MrPancakeare you still having an issue with this? Yes
Luke 42186 Posted December 26, 2022 Posted December 26, 2022 @MrPancake have you tried with emby server 4.7.11 and emby for Samsung 1.4.9?
MrPancake 10 Posted December 26, 2022 Author Posted December 26, 2022 4 minutes ago, Luke said: @MrPancake have you tried with emby server 4.7.11 and emby for Samsung 1.4.9? Yes, actually on the latest emby for Samsung it completely freezes up. With the version in the logs, a much older one, it hangs for 30 seconds then plays.
visproduction 328 Posted December 29, 2022 Posted December 29, 2022 Embysystem log shows continously errors showing no access to a directory. Perhaps fixing the directory access would help. This happens about 50 times a second. That probably doesn't help. Access to the path '/var/packages/EmbyServer/var/data/collections' is denied.
MrPancake 10 Posted December 29, 2022 Author Posted December 29, 2022 1 hour ago, visproduction said: Embysystem log shows continously errors showing no access to a directory. Perhaps fixing the directory access would help. This happens about 50 times a second. That probably doesn't help. Access to the path '/var/packages/EmbyServer/var/data/collections' is denied. Thank you for looking, I actually fixed that permission error, but it was unrelated.
Luke 42186 Posted December 29, 2022 Posted December 29, 2022 Is the TV on a wired connection or Wifi?
MrPancake 10 Posted December 29, 2022 Author Posted December 29, 2022 2 minutes ago, Luke said: Is the TV on a wired connection or Wifi? Wired
Luke 42186 Posted December 31, 2022 Posted December 31, 2022 On 12/29/2022 at 4:12 PM, MrPancake said: Wired Have you tried wifi just for comparison purposes? We have seen reports in the past where with some models the wifi actually outperforms the wired connection.
MrPancake 10 Posted December 31, 2022 Author Posted December 31, 2022 1 minute ago, Luke said: Have you tried wifi just for comparison purposes? We have seen reports in the past where with some models the wifi actually outperforms the wired connection. I'll try that tomorrow and let you know
MrPancake 10 Posted January 1, 2023 Author Posted January 1, 2023 14 hours ago, Luke said: Have you tried wifi just for comparison purposes? We have seen reports in the past where with some models the wifi actually outperforms the wired connection. Just tested, same issue. Would it be possible for me to send you the video file for testing? Maybe there's something wrong about it?
Luke 42186 Posted January 2, 2023 Posted January 2, 2023 21 hours ago, MrPancake said: Just tested, same issue. Would it be possible for me to send you the video file for testing? Maybe there's something wrong about it? HI, yes that would be fine. Thanks.
MrPancake 10 Posted January 2, 2023 Author Posted January 2, 2023 5 minutes ago, Luke said: HI, yes that would be fine. Thanks. Sent PM
