mcaphasia 2 Posted November 30, 2022 Posted November 30, 2022 I have a docker compose container with 5 volumes for various media. The first four show up fine, the last does not. All the files and directories have the same permissions. Is there some way to see what errors it's producing so I can figure out what's wrong with the volume? volumes: - /home/pi/docker/emby:/config # Configuration directory - /home/pi/leo/emby/tv:/mnt/tv # Media directory - /home/pi/leo/emby/movies:/mnt/movies # Media directory - /home/pi/leo/emby/mma:/mnt/mma - /home/pi/leo/emby/pitch.meeting:/mnt/pitch - /home/pi/leo/emby/shows:/mnt/liveshows is the relevant section, the live shows directory doesn't appear when I try to add the library Thanks
Luke 42245 Posted November 30, 2022 Posted November 30, 2022 Hi, where exactly does it not show up? Do you mean when using the directory picker? Did you try entering the path manually?
mcaphasia 2 Posted November 30, 2022 Author Posted November 30, 2022 Correct, I can't enter the path with the picker or manually. It's just not there at all. It's probably a docker issue. Just weird that everything is the same for all directories but this one is missing.
Luke 42245 Posted December 13, 2022 Posted December 13, 2022 hi @mcaphasia did you figure out how to get the docker volume visible to emby server?
mcaphasia 2 Posted December 13, 2022 Author Posted December 13, 2022 It appeared after pulling the new version. So no but it's working now. 1
