MSI2017 48 Posted November 30, 2022 Posted November 30, 2022 Hi all, I use cloudflare to put my emby behind a custom domain and ssl encryption. When inside the house I usually use app.emby.media (otherwise media gets uploaded to cloudflare and back to my home). However, even though secure connection is required I can still use app.emby.media outside my home network and use Emby. With chrome correctly flagging the connection as insecure. How can I prevent this, and how do I make sure the apps are using a secure connection? Thanks!
Luke 42186 Posted November 30, 2022 Posted November 30, 2022 Hi, have you customized any other emby server network settings?
MSI2017 48 Posted November 30, 2022 Author Posted November 30, 2022 3 hours ago, Luke said: Hi, have you customized any other emby server network settings? No, pretty sure it's all normal
MSI2017 48 Posted November 30, 2022 Author Posted November 30, 2022 3 minutes ago, Luke said: Can you show a screenshot? Thanks. Here you go, thanks for the help!
Happy2Play 9800 Posted November 30, 2022 Posted November 30, 2022 8 hours ago, MSI2017 said: When inside the house I usually use app.emby.media You are required to input https://app.emby.media for online app otherwise http is used. But dev would have to elaborate exactly what happens here. But will look for previous topics.
MSI2017 48 Posted November 30, 2022 Author Posted November 30, 2022 1 minute ago, Happy2Play said: Local sure, but remote also?
Luke 42186 Posted November 30, 2022 Posted November 30, 2022 The hosted web app will still use your https address to connect regardless, but yes you do have to make sure to use the https version.
MSI2017 48 Posted November 30, 2022 Author Posted November 30, 2022 1 minute ago, Luke said: The hosted web app will still use your https address to connect regardless, but yes you do have to make sure to use the https version. So the require secure connection for remote access does not count for app.emby.media?
Luke 42186 Posted November 30, 2022 Posted November 30, 2022 3 minutes ago, MSI2017 said: So the require secure connection for remote access does not count for app.emby.media? It does in the sense that it will still connect to your server with your https address, no matter which web app version you use. I explained the challenges with this in the bottom of this thread here:
