flyzarargentina 2 Posted November 29, 2022 Posted November 29, 2022 (edited) Usually I watch the movies through the local IP and IOS Safari browser. I am having the problem that the PLAY button does not work when it appears and the movie does not start automatically. It is only possible to play the movie by putting it in full screen and then press play. embyserver (1).txt Edited November 29, 2022 by flyzarargentina
Abobader 3485 Posted November 29, 2022 Posted November 29, 2022 Hello flyzarargentina, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42240 Posted November 29, 2022 Posted November 29, 2022 Hi, you could also click the Emby play button in the middle, right?
flyzarargentina 2 Posted November 29, 2022 Author Posted November 29, 2022 Yes I did, but it doesn't respond. The circle of loading remains spinning
Luke 42240 Posted December 11, 2022 Posted December 11, 2022 @flyzarargentina are you still having an issue with this?
fcarmonanatta 0 Posted December 11, 2022 Posted December 11, 2022 Hi Luke, yes, I still have the same problem. And apparently it's only on IOS. On Android it works fine. I think the problem is a bug with the pop-up on the screen to download the Emby app in the appstore. Before it appeared at the top of the screen and now it doesn't. And that makes the screen locked
redrobot2121 0 Posted December 20, 2022 Posted December 20, 2022 I am having same issue... I don't even transcode. Media plays well in 4.7.5.0 but having issue since updated to 4.7.10.0. don't know previous version in between them had any issue. media keeps on loading. server does not response to the get request from client
visproduction 335 Posted December 20, 2022 Posted December 20, 2022 Related forum discussion on this has been around for quite a while. The latest update in this discussion is only 12 days ago. https://stackoverflow.com/questions/20347352/html5-video-tag-not-working-in-safari-iphone-and-ipad
DabhidhUaghd 0 Posted March 1, 2023 Posted March 1, 2023 I was experiencing this issue too with my MD366RS/A (iPad 3rd Gen from 2012) running IOS 9.3.6 using the Safari web browser. I navigated through the Emby Library to a TV Series and pressed Play on an Episode then it would just sit and display the loading spinner indefinitely. I found that pressing the full screen button and then pressing play again the video would start working! When you leave full screen, the video continues to play.
Gecko 71 Posted March 7, 2023 Posted March 7, 2023 Another temporary solution : I used to put my iDevice in landscape and press the OSD Play Button (not the one from the iOS player) instead of going fullscreen because I noticed that in landscape, the OSD Play Button is shifted upward and can be pressed by the user, while in portrait mode, the button is below the iOS one, and you must instead tap a little bit offset to actually trigger it. Well it's hard to explain but anyway, still an annoying feature of iOS that autoplay does not work...
Luke 42240 Posted March 8, 2023 Posted March 8, 2023 19 hours ago, Gecko said: Another temporary solution : I used to put my iDevice in landscape and press the OSD Play Button (not the one from the iOS player) instead of going fullscreen because I noticed that in landscape, the OSD Play Button is shifted upward and can be pressed by the user, while in portrait mode, the button is below the iOS one, and you must instead tap a little bit offset to actually trigger it. Well it's hard to explain but anyway, still an annoying feature of iOS that autoplay does not work... HI, yes this is resolved for the next release of the server. the loading swirl is partially obstructing the play button in portrait orientation. For immediate relied it's also resolved on our hosted web app, http://app.emby.media 1
