Adorkable 9 Posted November 29, 2022 Posted November 29, 2022 (edited) I was using Home videos & photos。 The folder structure is similar to: Store\test3\pic\pic1.jpg Store\test3\pic\pic2.jpg Store\test3\V\test3-cd1.mp4 Store\test3\V\test3-cd2.mp4 This will cause multiple movies to display the same poster. The log shows that the cache images have been generated, but the thumbnails still show poster.jpg generated inside the folder and The generated metadata title will be marked with - cd1 If the folder structure changes to: Store\test1\test1-cd1.mp4 Store\test1\test1-cd2.mp4 The generated poster is specified as cd1,In this way, the thumbnails of each part are normal。 But I will put the same photos and videos in the same folder, otherwise it will be messy。 This is not the case in previous emby versions. It will correctly display thumbnails of all parts, and the title will not be marked with - cd1 I want to know whether this is a bug or whether the new version is designed like this?For this feature, I really like the previous version of emby。 I'm really troubled because most of my home images are stored like this. Finally, because I can't speak English, I can translate the above content. I'm not sure whether the translation is correct. I hope it won't affect your reading. log Edited November 29, 2022 by Adorkable
Luke 42186 Posted November 30, 2022 Posted November 30, 2022 Hi, this is the way that it's always been. I guess you'd have to manually assign images to part 2, part 3, etc. But more options are always possible for future updates. @Happy2Play ?
Adorkable 9 Posted November 30, 2022 Author Posted November 30, 2022 2 minutes ago, Luke said: Hi, this is the way that it's always been. I guess you'd have to manually assign images to part 2, part 3, etc. But more options are always possible for future updates. @Happy2Play ? But in previous versions, even if poster existed, the sections would show their own thumbnails instead of poster
Luke 42186 Posted November 30, 2022 Posted November 30, 2022 Ok I think I see an issue there. Thanks.
