Firewall not allowing Firestick to connect to Emby
I recently switched to Linux (Zorin 16 which is essentially Ubuntu) from Windows.  I wasn't able to get the Firestick to connect to the server unless I turn off the firewall.  Is there a simple setting that will allow Emby and my Firesticks/Rokus to connect?
Is there an incoming port that must be allowed?
Edited by moshmont
Never mind, I figured it out.  I set it up to allow incoming for ports 8096 and 8920.   Now it works!  🙂
  • Thanks 1
Thanks for following up.
