Jeffreypoze 4 Posted November 28, 2022 Posted November 28, 2022 Hello, I am having an issue where my metadata don't update automatically. I'm a fairly new to Emby, sorry if it's something I should know how to fix already. I create a folder for Cartoons and TV Shows, a few of them showed up ( Images, info etc ) and 90% just shows the name of the series without anything else. Therefore it shows an empty folder with images and seasons. If I click on Identify and manually type the name and do search, the seasons, episodes and images shows up. I refresh metadata, scan library, installed coverart plugin. Still not working. My Movies folder is the only one that updated and working properly. I am on Windows 11 using Chrome and have Emby Premiere. Any help would be appreciated. Running Tasks been stuck there for over 4 Hours I stopped and restarted it with same result Log file attached. embyserver.txt
Abobader 3485 Posted November 28, 2022 Posted November 28, 2022 Hello Jeffreypoze, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42186 Posted November 28, 2022 Posted November 28, 2022 Hi there, is there a problem with the permissions of your X drive? 2022-11-28 01:42:43.627 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.7.10.0 Command line: G:\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22621 Framework: .NET 6.0.10 OS/Process: x64/x64 Runtime: G:/Emby-Server/system/System.Private.CoreLib.dll Processor count: 6 Data path: G:\Emby-Server\programdata Application path: G:\Emby-Server\system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path 'X:\Cartoons\American Dad!\Season 11\American Dad! - S11E02 - A Boy Named Michael.nfo' is denied. You enabled saving to nfo files, but the server is being denied write access to create them.
Jeffreypoze 4 Posted November 28, 2022 Author Posted November 28, 2022 Hi @Luke I disabled saving nfo files, refresh metadata, scan library. Still same issue. embyserver.txt
Jeffreypoze 4 Posted November 28, 2022 Author Posted November 28, 2022 No permission issue, my movies folder is on the same drive and worked fine.
Luke 42186 Posted November 28, 2022 Posted November 28, 2022 2022-11-28 03:07:28.299 Info App: Loading ChapterApi, Version=1.3.0.6, Culture=neutral, PublicKeyToken=null from G:\Emby-Server\programdata\plugins\ChapterApi.dll 2022-11-28 03:07:28.299 Info App: Loading Douban, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null from G:\Emby-Server\programdata\plugins\Douban.dll 2022-11-28 03:07:28.299 Info App: Loading Emby.MediaInfo, Version=1.0.1.18, Culture=neutral, PublicKeyToken=null from G:\Emby-Server\programdata\plugins\Emby.MediaInfo.dll 2022-11-28 03:07:28.300 Info App: Loading XmlMetadata, Version=3.5.0.0, Culture=neutral, PublicKeyToken=null from G:\Emby-Server\programdata\plugins\XmlMetadata.dll Hi, please try removing these plugins, then restart the server and see how that compares. You'll need to refresh the metadata manually on content that has been impacted. Thanks.
Jeffreypoze 4 Posted November 29, 2022 Author Posted November 29, 2022 @Luke I did, seems like the metadata are showing up slowly for some stuffs not all of them. Been at 85% for 5 hours. I'll let it run all night and see in the morning. Will post an update, Thank you 2
Happy2Play 9800 Posted November 29, 2022 Posted November 29, 2022 Yes initial scans can be lengthy, and percentage is not always a good indicator.
Luke 42186 Posted November 29, 2022 Posted November 29, 2022 % is just based on number of files, but some items can take longer than others.
Jeffreypoze 4 Posted November 30, 2022 Author Posted November 30, 2022 Yea, seems that it’s the initial scan that’s still going on for 2 days haha. A lot more files are showing up now with proper metadata etc. I’ll wait until the weekend and see. Thank you very much for the assistance 1
Jeffreypoze 4 Posted January 17, 2023 Author Posted January 17, 2023 @Luke sorry for the late reply, after 5 days, it was updated.
Luke 42186 Posted January 17, 2023 Posted January 17, 2023 19 hours ago, Jeffreypoze said: @Luke sorry for the late reply, after 5 days, it was updated. Are you all set now?
Jeffreypoze 4 Posted January 17, 2023 Author Posted January 17, 2023 Yes, from time to time it won't scan the folders properly but if I run it manually it does. Thank you 1
