Wannacry 1 Posted November 27, 2022 Posted November 27, 2022 Hi, I bought the premiere but the "skip intro" doesn’t work. I tried to do it manually by clicking on the “play” icon and it didn’t scan. can I have some help please?
Abobader 3485 Posted November 27, 2022 Posted November 27, 2022 Hello Wannacry, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2024 Posted November 27, 2022 Posted November 27, 2022 How many episodes do you have? The software compares the audio and detects matches between different episodes; and I think it requires a minimum of three episodes to ensure reliable recognition. Paul
Wannacry 1 Posted November 27, 2022 Author Posted November 27, 2022 1 hour ago, pwhodges said: How many episodes do you have? The software compares the audio and detects matches between different episodes; and I think it requires a minimum of three episodes to ensure reliable recognition. Paul Thank you for your reply. I have more than 100 episodes
ebr 16307 Posted November 27, 2022 Posted November 27, 2022 26 minutes ago, Wannacry said: I have more than 100 episodes Of the same season of the same show? Can we please look at specifics of an example?
Wannacry 1 Posted November 27, 2022 Author Posted November 27, 2022 11 minutes ago, ebr said: Of the same season of the same show? Can we please look at specifics of an example? Hi ebr, I have a total of 70 Tv shows with more than 100 episodes. thank you
Happy2Play 9800 Posted November 27, 2022 Posted November 27, 2022 If they are not detected on first go round, I believe they require to be Refreshed to attempt again. Have you checked the episodoes with Chapter API plugin?
Wannacry 1 Posted November 27, 2022 Author Posted November 27, 2022 4 minutes ago, Happy2Play said: If they are not detected on first go round, I believe they require to be Refreshed to attempt again. Have you checked the episodoes with Chapter API plugin? Hi Happy2Play, I didn't checked the episodes with Chapter API plugin, I''m going to try. Thank you
Wannacry 1 Posted November 28, 2022 Author Posted November 28, 2022 The skip Intro doesn't work only on my Apple TV. It works on my Nvidia shield pro and Mac mini. is it an issue with the Apple TV?
samuelqwe 317 Posted November 28, 2022 Posted November 28, 2022 23 minutes ago, Wannacry said: The skip Intro doesn't work only on my Apple TV. It works on my Nvidia shield pro and Mac mini. is it an issue with the Apple TV? Yes, Apple TV does not yet support intro skipping. I think they’re working on it though, the Apple TV app is undergoing major changes so that it will be easier to add features like this in the future. 1
Solution Luke 42186 Posted November 28, 2022 Solution Posted November 28, 2022 25 minutes ago, Wannacry said: The skip Intro doesn't work only on my Apple TV. It works on my Nvidia shield pro and Mac mini. is it an issue with the Apple TV? Hi, it hasn't been added to the Emby Apple TV app yet but is on the way, so stay tuned.
Wannacry 1 Posted November 28, 2022 Author Posted November 28, 2022 3 minutes ago, samuelqwe said: Yes, Apple TV does not yet support intro skipping. I think they’re working on it though, the Apple TV app is undergoing major changes so that it will be easier to add features like this in the future. Thank you samuelqwe for the information.
Wannacry 1 Posted November 28, 2022 Author Posted November 28, 2022 5 minutes ago, Luke said: Hi, it hasn't been added to the Emby Apple TV app yet but is on the way, so stay tuned. Thank you very much Luke. 1
