AlfonsoS 0 Posted November 27, 2022 Posted November 27, 2022 Hi, I Enjoyed Emby and also unlocked the App but now from overnight I can no longer connect to my Emby Server from other devices (fire TV, Android TV and iOS) either app or browser. I can use my Emby Server only on Mac OS. Note that my Firewall is disabled in Mac OS Settings, so what's the problem? Please help
Luke 42239 Posted November 28, 2022 Posted November 28, 2022 Hi there, what exactly happens when you try to connect?
AlfonsoS 0 Posted November 28, 2022 Author Posted November 28, 2022 Hi, thank you for your reply. I think I've solved it. It has been necessary to disable the "WPS" router option in my Vodafone Station settings. But it has always been active, why now do I need to disable this to use Emby or any other local server? By the way before the fix, the iOS App or Web App in Browser just failed the connection to the server trying to add a new Server in Emby... anything more.
Luke 42239 Posted November 29, 2022 Posted November 29, 2022 On 11/28/2022 at 4:18 AM, AlfonsoS said: Hi, thank you for your reply. I think I've solved it. It has been necessary to disable the "WPS" router option in my Vodafone Station settings. But it has always been active, why now do I need to disable this to use Emby or any other local server? By the way before the fix, the iOS App or Web App in Browser just failed the connection to the server trying to add a new Server in Emby... anything more. Hi, to be honest, I'm not sure. I've never heard of anyone having to do this before. Is it consistent if you flip the option back and forth?
