rigo8582 16 Posted November 3, 2014 Author Posted November 3, 2014 E: was a local drive I used for troubleshooting. I wanted to verify the symptoms would be the same. The rest I used UNC path for the library. I realize I'm in the minority. But how difficult would be to implement the metadata "refresh" into the scheduled tasks? If I was able to have it scan once a night would be just fine.
Luke 42301 Posted November 3, 2014 Posted November 3, 2014 your best bet is to just turn off the realtime monitor
TrackZ 16 Posted November 3, 2014 Posted November 3, 2014 I've noticed this for a while now too. ISOs on initial scan don't get media info and such populated. You have to run a manual refresh for that info to get parsed and shown. It's does work fine picking up the details in the refresh though. 1
rigo8582 16 Posted January 2, 2015 Author Posted January 2, 2015 your best bet is to just turn off the realtime monitor I've using that for the past few weeks, and it hasn't made any difference.
Luke 42301 Posted January 2, 2015 Posted January 2, 2015 Ok, well bear in mind that our ability to extract media information from Iso's is only considered experimental. The tools we rely on don't natively support them.
