AIoTMYNAS 1 Posted November 26, 2022 Posted November 26, 2022 Hi all, I'm faced with metadata and pictures loading problem since the beginning of November (Synology NAS DS920+). For the sake of interest, I connected the NAS via VPN (Netherland) and all the pictures (movie descriptions) loaded immediately. Please specify the addresses of the sites from which metadata and images are downloaded, I will add their routing via VPN on the router.
Luke 42239 Posted November 26, 2022 Posted November 26, 2022 Hi there, can you please provide a specific example of a problem? How to Report a Problem Thanks.
AIoTMYNAS 1 Posted November 26, 2022 Author Posted November 26, 2022 10 minutes ago, Luke said: Hi there, can you please provide a specific example of a problem? How to Report a Problem Thanks. FYI embyserver.txt
Happy2Play 9811 Posted November 27, 2022 Posted November 27, 2022 @AIoTMYNAS Are you able to update from 4.6.7.0 to the latest server version? System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
AIoTMYNAS 1 Posted November 27, 2022 Author Posted November 27, 2022 8 hours ago, Happy2Play said: @AIoTMYNAS Are you able to update from 4.6.7.0 to the latest server version? System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. No, there is not availaible update from Synology package center.
Happy2Play 9811 Posted November 27, 2022 Posted November 27, 2022 @AIoTMYNAS But is available via download page and GitHub. Unfortunately, updates are extremely slow to get to the package center.
AIoTMYNAS 1 Posted November 27, 2022 Author Posted November 27, 2022 27 minutes ago, Happy2Play said: @AIoTMYNAS But is available via download page and GitHub. Unfortunately, updates are extremely slow to get to the package center. Attached lo file after update. embyserver.txt
Happy2Play 9811 Posted November 27, 2022 Posted November 27, 2022 On 11/26/2022 at 2:01 AM, AIoTMYNAS said: Please specify the addresses of the sites from which metadata and images are downloaded, I will add their routing via VPN on the router. Most of this will not be known to us on how those providers route their data for other countries. This could be VPN related. But could have a look here (api.themoviedb.org) DNS Checker - DNS Check Propagation Tool From discussion here https://emby.media/community/index.php?/topic/112084-4808-测试版增加的新电影不能识别及播放
Luke 42239 Posted November 28, 2022 Posted November 28, 2022 Hi, have you tried disabling the VPN for comparison purposes?
AIoTMYNAS 1 Posted December 5, 2022 Author Posted December 5, 2022 So, to solve this problem on Synology i was create VPN connection to Netherlands server with routes like as an screenshots. 1
