Revenent 15 Posted November 25, 2022 Posted November 25, 2022 Emby Server 4.7.10.0 Seeing this weird guide bug where if I just land on the page and start scrolling horizontally, the date jumps radically, and eventually I stop seeing items in the guide. For example, I scroll a bit over (as in about 6 to 7 hours worth in the guide), and the date is already into January, but when I click on an item, it is showing the correct date: Note the top left date, and the date of the item. If I let the page sit for a while (as in minutes), the page starts working properly again. But refreshing the page causes this to happen again. I didn't notice this 4.7.8.0, but I usually use the guide on Theatre or on a device - and those don't seem to be affected even on the 4.7.10.0. It looks like the data is there, since if I click on the channel, I can scroll down and see all the shows. Was there something introduced in 4.7.9.0 or 4.7.10.0 that caused this? Thanks!
Revenent 15 Posted November 25, 2022 Author Posted November 25, 2022 OK, tried a few more things. When I land on the page, if I refresh the page - possibly twice - the guide pops up the right arrow, meaning it is "working" again. But if I click on the Home button and then back into the Guide, it goes back to the bad state, and I have to refresh it again to get it to work.
Luke 42290 Posted November 25, 2022 Posted November 25, 2022 Hi, yes I have seen this a few times and am investigating. Thanks for reporting.
