psi 1 Posted October 11, 2014 Posted October 11, 2014 everying works vis playing video, even HD with practically no load on the PC. its just finding the programs, after dozens of different attemps, (different program versions, all the settings and many many different folder structures.) i can only get this, on root of "tv series" (see attached), one layer further down the names and episodes are appearing fine. i have used this guide to made folder structure; http://mediabrowser.tv/community/index.php?/topic/674-media-files-folders-structure/ and have discovered this, along the way; file names cant be very long, files need to have an extension BTW i do have, i think, an unual system, linux with the server running in a container and a "now TV" box (roku lt) with the player side loaded, but cant see this is relavent since everything else works.
Luke 42243 Posted October 11, 2014 Posted October 11, 2014 Do you see the names in the web client? if so it is probably just a bug in the roku app.
psi 1 Posted October 12, 2014 Author Posted October 12, 2014 never used the web clent, just have, everything seems fine there. i'll update to the latest roku player, seems to be being updated often, if its still there i'll report, thanks again. 1
