Shiki214 0 Posted November 22, 2022 Posted November 22, 2022 A single ASS subtitles usually contains multiple fonts, but it seems that Emby haven't been able to handle the fonts in ASS subtitles yet, instead Emby uses a default font to display all the subtitles. I've installed all the fonts that declared in ASS subtitles files in both Emby-server(windows server) and client windows10/Android machine, but it doesn't work at all. Is there a way to ensure all the fonts display correctly? Or would Emby add a new feature to solve this problem? [VCB-Studio] Haiyore! Nyaruko-san [01][Ma10p_1080p][x265_flac].ass
Solution Luke 42238 Posted November 23, 2022 Solution Posted November 23, 2022 Hi, you are right, we do use a default font. We are working on improving it though. Thanks. 1
softworkz 5133 Posted November 23, 2022 Posted November 23, 2022 20 hours ago, Shiki214 said: A single ASS subtitles usually contains multiple fonts, but it seems that Emby haven't been able to handle the fonts in ASS subtitles yet, instead Emby uses a default font to display all the subtitles. I've installed all the fonts that declared in ASS subtitles files in both Emby-server(windows server) and client windows10/Android machine, but it doesn't work at all. Is there a way to ensure all the fonts display correctly? Or would Emby add a new feature to solve this problem? This is working in the latest betas when you install the Diagnostics Plugin and then go to the "Diagnostic Options" page where you can "Enable Subtitle Filtering".
