dcol 177 Posted November 21, 2022 Posted November 21, 2022 The Emby database is definitely its weakest part. I have had to delete libraries countless times over the past because of the built in database. Had to do it just last week again because bad data would not purge out. All I did was remove a plugin because the metadata info was incorrect. The incorrect data would not go away.
Luke 42301 Posted November 21, 2022 Posted November 21, 2022 Hi @dcol, can you please provide a specific example? I moved your posting because it has nothing to do with which database engine the server is using. Thanks.
