Panda1986 0 Posted November 19, 2022 Posted November 19, 2022 Hello everyone, I am trying to make Emby server working but I am not able to make that... I tried to use arm but also a X64 variant of the program but it cannot be installed on my NAS. I unpacked both packages an found a same definition file (in install.rdf file I can find only Thecus N2800 and N16000). Is it possible to run it somehow on my Thecus N4350?
Luke 42234 Posted November 19, 2022 Posted November 19, 2022 Hi there, what exactly happens when you try to install?
Panda1986 0 Posted November 20, 2022 Author Posted November 20, 2022 (edited) Hi, here is the log of the install of the arm variant: 2022/11/20 22:49:25: The App will install/upgrade, please do not reload or close the admin UI 2022/11/20 22:49:33: App Name : [ Emby Server ] 2022/11/20 22:49:33: App Version: [ 4.7.9.0 ] 2022/11/20 22:49:33: App installation failed because can not find Protocol: [ N2350 ] in install.rdf 2022/11/20 22:49:33: App installation failed. Same message if I try to install x64. 2022/11/20 22:51:22: The App will install/upgrade, please do not reload or close the admin UI 2022/11/20 22:51:37: App Name : [ Emby Server ] 2022/11/20 22:51:37: App Version: [ 4.7.9.0 ] 2022/11/20 22:51:37: App installation failed because can not find Protocol: [ N2350 ] in install.rdf 2022/11/20 22:51:37: App installation failed. My NAS is Thecus N4350 (the NAS as N2350 but with four bays). 2022/11/20 22:49:25: The App will install/upgrade, please do not reload or close the admin UI 2022/11/20 22:49:33: App Name : [ Emby Server ] 2022/11/20 22:49:33: App Version: [ 4.7.9.0 ] 2022/11/20 22:49:33: App installation failed because can not find Protocol: [ N2350 ] in install.rdf 2022/11/20 22:49:33: App installation failed. Edited November 20, 2022 by Panda1986
alucryd 318 Posted November 21, 2022 Posted November 21, 2022 (edited) Just to be sure, is it 4350 or 2350? The log complains about the latter. Edit: Nevermind, I'll just add both. Edited November 21, 2022 by alucryd
Panda1986 0 Posted November 21, 2022 Author Posted November 21, 2022 Hi aucryd, I have 4350 for sure (difference is only number of bays, and I have 4 of them). But, log says what I copied. Can I download and try?
alucryd 318 Posted November 22, 2022 Posted November 22, 2022 Please give the latest beta a try: https://github.com/MediaBrowser/Emby.Releases/releases/download/4.8.0.19/emby-server-thecus_4.8.0.19_arm_32.mod We will have a stable release available for download shortly if that works for you. 1
Panda1986 0 Posted November 22, 2022 Author Posted November 22, 2022 I am able to install it 2022/11/23 04:07:05: The App will install/upgrade, please do not reload or close the admin UI 2022/11/23 04:07:14: App Name : [ Emby Server ] 2022/11/23 04:07:14: App Version: [ 4.8.0.19 ] 2022/11/23 04:07:14: App is installing ... 2022/11/23 04:07:31: App installation successful. And it is working I will test it and give you a feedback. Thank you very much! 2022/11/23 04:07:05: The App will install/upgrade, please do not reload or close the admin UI 2022/11/23 04:07:14: App Name : [ Emby Server ] 2022/11/23 04:07:14: App Version: [ 4.8.0.19 ] 2022/11/23 04:07:14: App is installing ... 2022/11/23 04:07:31: App installation successful.
Panda1986 0 Posted November 22, 2022 Author Posted November 22, 2022 Yes, it is fully working, I can see DLNA server from any TV in the house. Thank you
