frankmb 41 Posted November 18, 2022 Posted November 18, 2022 (edited) If I fast forward to the end of an episode that is transcoding, then push play to resume and finish the <10 last seconds, it gets stuck on a spinning circle with percentage. So in this case the episode is impossible to complete normally and I need to push the back button. See pictures. If I do the same on a episode that direct plays, the last few <10 seconds will play normally and the episode ends normally. Edit: Added server and ffmpeg logs. embyserver.txt ffmpeg-transcode-7e348cbf-5a4c-4542-865a-6f2b4400897c_1.txt Edited November 18, 2022 by frankmb
Happy2Play 9811 Posted November 18, 2022 Posted November 18, 2022 Devs will probably need to see server and ffmpeg log but only guess something with processing the last segment.
frankmb 41 Posted November 18, 2022 Author Posted November 18, 2022 15 minutes ago, Happy2Play said: Devs will probably need to see server and ffmpeg log but only guess something with processing the last segment. Ok. I added the logs.
Happy2Play 9811 Posted November 18, 2022 Posted November 18, 2022 If you go to the second to last interval image, does it work? I am guessing something with that last 3 second segment. But devs will have to look at the technical aspects.
Luke 42240 Posted November 18, 2022 Posted November 18, 2022 1 hour ago, Happy2Play said: Devs will probably need to see server and ffmpeg log but only guess something with processing the last segment. Exactly, yes. We are looking into it. There is a similar topic already. Luckily it won't affect every single video.
